Page 13 of 15 FirstFirst ... 39101112131415 LastLast
Results 241 to 260 of 1445
    tulong!!! saan ko po makikita ang WALCO dito sa Banawe?
    Posted via Tsikot Mobile App
    nahanap ko Walco kanina.
    Apr 2014
    Good afternoon mga sir. Nagkaroon po ng butas yung radiator ng 4JG2 (imported). Ano po kaya ang magandang replacement brand mga sir? Advisable po ba ang repair? San po magandang repair shops near Retiro/Maceda? Thank you mga sir.
    Quote Originally Posted by kimpuy30 View Post
    ok lang naman po ang repair as per my experience basta ok po yung pag lanang at ma cocover yung buong butas..
    Jul 2003
    Mga bro saan makakabili ng coil spring OME 912? Thanks
    Jul 2014
    Hi guys good day i would like to ask any advice with my isuzu trooper 99 4jx1 m/t . Lately i notice our trooper has a low power lalo na pag hill climbing, pinalitan na namin yung injector assembly since yun yung advise ng casa. At inayos na namin yung catalytic converter..and pinalitan narin yung throttle sensor. when we did a test drive nag improve siya ng konti pro still mabagal parin pag hill climb.. 2nd gear *rpm of 3000 20kph lang yung takbo pag mag shift ka naman sa 3rd gear namamatay yung engine. If familiar kayo sa TOPS dito sa cebu doon kami nag test drive. Thank you and god bless
    Oct 2013
    Quote Originally Posted by chad611 View Post
    ilan km na yan? ako hula ko fuel delivery problem... barado sa madumi diesel ng pang jeep sa pinas gamit mo cguro... malinis kase diesel sa japan kung saan naka design ang trooper...
    Jul 2014
    Quote Originally Posted by Stigg ma View Post
    175,000 km na po sir, yung diesel ginagamit ko is V.power nitro diesel.
    I try mo pa check ang fuel pump pressure ng engine mo.high pressure pump kc ang gamit ng 4jx1,try to disconnect the fuel line going to common rail injectors and start your engine and subukan mo pigilin using your thumb or mas maganda kung dalhin mo sa calibration center para makita kung ilang psi ang pressure nya.pag mahina na kc ang bomba sure na kakapusin na sa higop ng diesel kaya hirap humatak.try mo din icheck ang fuel line and fuel filter bka barado...sana maka tulong sayo...
    Jul 2014
    Quote Originally Posted by wizard4jx1 View Post
    Good day thank you sa advice.. Pag may time aku dadalhin ko yung sasakyan sa calibration center. Uhm tanong ko lang i notice yung feed pump di na siya tumitgas pag mag bleeding ka is it normal? And regarding sa pressure pump, ma dadaignose mo ba yun thru tech 2?
    Oct 2003
    Hello guys. I know this is an Isuzu Trooper thread pero ask ko na rin dito: is a 2003 trooper 4JX1 a good buy these days? Naplitan na daw fuel injectors nito dati sa casa. Worry ko lang since its a fairly old car na, baka isa-isa nang maglabasan ang mga sira (although now ok naman lahat).
    Jan 2014
    Ok pa yan
    basta wag mo sa tabi-tabi ipagawa yan at fuel mo dapat ung malinis
    di siya katulad ng crosswind, pajero na kahit saan ok lang
    Ok pa yan
    Feb 2015
    Kung sira po ba ang comp box hindi na aandar ang sasakyan? Just asking po. Ty sa sasagot. Nakalight check engine ano po ba maganda gawin? And super puti napo ng usok. Sorry bago kuha ko lang unit. Hope u can help me.ty
    Feb 2015
    4jx1 po ang trooper ko 2003 model
    Feb 2015
    Sir up lang po ng thread:
    question po sa mga guru ng trooper.
    Ung officemate ko may trooper (i believe 4jx1 engine kasi 3.0),
    Ok naman tumakbo, pero nahihinaan na daw siya sa makina, pero he already clocked around 140k kms and i think 2000 or 2001 model ung kanya.
    Paakyat daw ng bridge sa ortigas, hirap ba hirap at sobrang bagal niya.
    Question mga sir, eto na ba ung relative sa fuel injection or sa turbo niya? Sorry hindi ko na po mabasa lahat.
    Ung abs niya umiilaw paminsanminsan din po, pero nabasa ko na nakukuha sa linis.
    Help po mga idol.
    Aug 2009
    good pm guys, need your help
    2003 isuzu trooper skyroof local 4jx1 engine edition
    1) umiilaw ang oil pressure indicator light when i started kanina ( hindi ko na pinatakbo)
    2) palaging dead bat ( kahit ok ung alternator) battery bough 2014 april
    3) no power when going uphill
    pls help thank you
    pls help thank you
    Sep 2008
    anyone here with a 4JG2 local trooper na first owner until now?
    Jan 2010
    Good morning mga trooper owners!i'm a proud owner of an isuzu bighorn 1994 4jg2 engine.
Isuzu Trooper discussion
