Which sir? alterra, xwind and dmax? ako no choice but the service car "trooper" hahaha.
Sige ba, post ako ng top speed! kwento pa saken pag puno daw yun di na kaya lumampas ng 100kph. Lets see sa june pa naman ako sa pangasinan at kung may prob, kokonsulta ako dito.
Pasingit ako dito, di ko lang matiis ishare
I can still squeeze 180 kph at 4000 rpm on my 10 year old trooper (halos magred line na nga lang)
Sir sleepy madalas ako sa dagupan kase andun folks ko. Ano plate number ng troop ng uncle mo? baka yan yung madalas kong makita na nakapark sa hotel near Isuzu Inteco Dagupantawag ko dun sa unit na yun eh "sticker happy" censha na sir ha, napagkatuwaan ko lang yung name
ooops sorry double post, erratic net connection kase dito sa bundok hehe
Last edited by wonderingwil; May 22nd, 2009 at 01:21 AM. Reason: oops.. sorry double post
Up ko lang sa ride ko.
di tinuloy pag release kahapon.
namamatay parin daw. tsk tsk.
tech2 reading is normal exept on oil and fuel pressure (?)![]()
gandang araw ng bro/sirs,
bago lng po ko dito & i also like to share my experience sa trooper ko & hoping i could also find ways and help sa present problem ko...
my bighorn is a 96 imported (subic) 4JG2 engine which we have been using since 2003..No much problem...regular maintenace lng..i could run up to 160kph...i been to nueva icija & baguio several times...Im from Tagaytay po pala... We went to tarlac 3 weeks ago...unluckily on our way back home, one waterhose side of the block below the turbo got busted...
so without knowing im running without water...obviously overheat...
i towed my trooper back home....
according to our mechanic he can repair the engine eventhough it is his first for this type of engine....
He changed the cylinderhead gasket, timing belt, water pump,.....
Today, i been using my trooper for 2 weeks already....
the preblem now is..there is s white smoke coming from the exhaust when u start the engine for few seconds...after which it will run normally...another thing during our first start there is a hissing sound which i guess is coming form the turbo and until now it is still there...my mechanic tried to check the hoses but just the same the sound is still there.....
I am worried that the cylinderhead gasket was not properly installed nor the turbo....
hope someone could advice or help me...i know CASA is expensive & im not sure wether isuzu imus would accept me...one thing di ko pa po kaya mag casa....meron po ba me alam kung ano filler gauge sa adjustment ng Valves for the 4JG2 engine?
tns po
Bro yung trooper mo ba namamatay pag nirev mo ng mataas tapos sabay bitaw sa gas pedal? and yung oil pressure mo asa 1/4 dun sa gauge tas mababa ang idle? try mo lang to, wala naman mawawala. Ganyan din kase naexperience ko before, di rin nasolve ng mga tiga casa. Ask them to drain all of the fuel sa troop mo then bili ka lang maski 3 liters of diesel fuel sa Petron (dapat binabayaran ako ng petron dito eh, libre advertising to). Dapat yung bago or malaki na gas station para sigurado malinis yung fuel. Try mo na yun ang gamitin and see if namamatay pa rin ang engine mo.
Hello,
I want to restore our old trooper back to good condition. its a 97 3.1 diesel m/t model.
can anyone point me to the right direction on what i need to check/replace?
oil
oil filter
fuel filter
coolant
tranny fluid
brake fluid
p/s fluid
anything else? btw what we always do is just to blow the air filter with compressed air every now and then.
ganon ba talaga yung old diesel trooper? makalog at maingay?
thanks
mga bossing
tanong ko lang kung may alam kayo na trusted na mekanico para sa trooper pa check ko sana makina ko at Shift on the Fly System kc lagi naka ilaw sa dashboard na naka 4wd sya kahit hindi naman naka kambyo sa 4wd, dati naman hindi sya ganun "off" kaagad yung ilaw pag binalik yung kambyu sa 4wd to neutral ng isuzu Bighorn 4JG2T (3door) subic.
salamat....
yung Trooper ko ayaw mawala nung ABS warning light. :shocked2: ano kaya problem?
