Page 128 of 186 FirstFirst ... 2878118124125126127128129130131132138178 ... LastLast
Results 2,541 to 2,560 of 3710
    Oct 2013
    #2541
    30K PMS w/ aircon cleaning quote from isuzu casa
    Labor
    change oil -375
    tune up - 375
    pull-out tires clean/adjust break - 750
    tighten all body bolts/nuts - 188
    aircon cleaning - 1875
    misc - 200
    Parts
    motor oil - 1,380
    oil filter - 1,100
    fuel filter - 465
    brake cleaner - 125
    drain plug gasket - 43
    tiptop - 333
    engine flushing - 465
    freon - 1800
    capilla oil - 250
    aircon cleaner 300
    Total: 10,034
    tsikoters kindly comment for 1. motor oil is this isuzu genuine oil price? 2. how much po kaya sa rapide or yokohama same package for 30K PMS?
    thanks
    Sep 2009
    #2542
    ^labor pa lang taga na! demet!
    sa rapide kamo? sa rapide ba ulit kamo?
    baka umuwi kang luhaan at baka sana na-isip mo sa casa ka na lang.
    punta ka sa goon squad and read about rapide horror stories.
    Sep 2013
    #2543
    Baka may idea po kayo kung ano yong nag iingay inside the gas tank po ng xwind. kahit d po sya nakaandar tapos tinulak back and forth nag iingay po sya na parang lata sa loob ng gas tank.
    Oct 2013
    #2544
    mga sir newbie lng po..patulong naman po got my 2nd hand crosswind manual xuv le 2010 last june i traded may 2006 adventure..bago kopo kinuha yun nagbabasa po ako dito..kaya sabi ko goodbuy ang crosswind..until now...marami narin po ako napagawa like leaking radiator.cleaning ng nozzle..nawala naman yung maitim na usok.change oil air filter fuel filter.kona pero ganun padin. sya may problem is hirap parin hamutak... lakas kumain ng krudo mga 6klm per liter lng sya as in grabe ..tinawagan ko nga yung diesel calibration na pinagpalinisan ko ng nozzle sa muntinglupa sabe niya kaylangan na daw pa check yung injection pump baka dun daw barado kaya hirap humatak at lakas sa krudo..kaylangan naba agad yun samantalang modelo pa yun unit ko..gastos nanaman ..anu po ba ang gagawin ko..wala na ko peace of mind kakaisip ng mga problema..completo po record ito sa pms ng last ng may ari sa gencars makati.pero bakit ganun parin..pls help po ..im from laspinas baka may kilala kayu na pagpapagawaan
    #2545
    Quote Originally Posted by Bastikurt View Post
    Dalhin mo yan sa Berrima Diesel and I can guarantee you na titino yang sasakyan mo. Dyan ako nagpa tune ng XTO at FM ko. Hindi marunong mag tune ang mga casa.Tawag ka muna para sa appointment.
    Eto yung address nila.
    219 J. P Rizal St. Brgy. Mabini - J. Rizal,
    1150 Mandaluyong City, Philippines
    Phone # : 02 533-1415
    #2546
    Bro join ka sa Team Isuzu Pilipinas Facebook, me crosswind club dun. they can help you a lot on the cheaper route.. pa check ng Nozzle tips baka mali ang preassure nya. you can either go to central diesel in quezon ave. or there's one in Kamuning called Kingston calibration highly recommended ng Isuzu boys yun... If you want it tuned theres a guy they recommend too called "badong" he can tune your x-wind a heck of a lot cheaper than Berime (sorry Nelany peace! hehehe)
    Quick fix lang, change your fuel filter boss ... me available na fleetguard brand para dyan
    #2547
    No problem hehehe Mahal kasi sila dahil Dyno tuning ang gamit nila. Can see the improvement before and after tuning thru chart and actual road test.
    Oct 2013
    #2548
    thx mga bro nelany and blue_gambit sa concern..south area ako kaya hirap puntahan yung mga addvice ninyu na calibration center..pinaayos kona kanina dito sa muntinglupa sa helix calibration center..sofar nung hinataw ko sya sa slex from susuna heights goin to felinvest okey na yung hatak at mabilis na reach ko 100kph.. yung rpm ninya di gaya ng dati na lubog na yun tapak ko nasa 2000rpm palang.ngayun mabilis na yung response ng makina..dati parang slomu yung palu ng needle ng speedometer .obserbahan kopa kung titipid na sa krudo..nagpalit na din ako ng mga fuelfilter sinabay ko nun nagpachange oil ako.lastweek..kaya nagtaka ako bakit wala parin hatak..kaya naisipan kona humingi ng addvice dito..nagdecide na nga ako pacalibrate na....yung mga pinalitan is transper pump,.regulating vavle..,driveshaft bushing oilseal..ang damage ko 6680 petot pinanuod ko nga panu ginawa before and after dun sa testingan nila n parang generator na may computer..convincing nman na may problema talaga injector pump ko inabot din ng 4hours.hopefully maging matipid na sya sa krudo .bro tagal nako nagrequest add sa team isuzu pilipinas dipa nila accept..
    Jan 2011
    #2549
    pm mo si sir joel sa fb niya. sana ok na xwind mo. just a piece of advise sir, use 2t in your fuel. it may be the culprit why your injection pump has been damage. there is a lot of positive review on the use of 2t on our diesel cars, esp isuzu.
    Oct 2013
    #2550
    okey sir shelu sa info ..mukhang okey nga 2t binasa ko yung mga lumang tread about 2t dito naliwanagan nako about 2t as additives sa diesel..dati kasi diko pinapansin yun kala ko haka haka lng..mukhang maraming nagpapatotoo..masubukan agad bukas..yung last kasi na may ari ng crosswind ko babae inasa lng lahat sa casa ang maintenance kaya siguro di naalagaan mabuti..ang crosswind niya.. kaya binenta agad..malaking tulong talaga itong tread na ito sa mga natutunan ko about how to maintain our crosswind..thx again
    Sep 2010
    #2551
    Good Evening mga sir! We traded our Crosswind '04 (naturally aspirated) for a 2010 Sportivo M/T Turbo.
    Since newbie po ako sa may turbo, ask ko lang po kung normal lang na parang na cho-choke ang engine pag
    lumalampas ako sa 2000rpm when in 1st to 3rd gear? pag nasa 4th and 5th gear ok lang po pati na sa neutral.
    Sabi nung previous owner "normal lang yan, turbo kasi". I find it unusual po. Please advise. TIA!
    #2552
    Quote Originally Posted by gdflores_168 View Post
    choke as in parang mamatay ang makina? di ko pa na experience to na related sa Turbo. Sa akin pag nag engage yg turbo parang sumisibad pa nga.
    choking experience ko ay related sa fuel filter at separator sediments. change the former, clean/flush the latter. it may help isolate the problem.
    Sep 2010
    #2553
    Tnx sir 14myXUV, opo sir. As in parang palyado na kakadyot. Pero kanina as I Accelerated gradually, umabot cya mahigit 2500rpm in 3rd gear. Pag biglang arangkada, nasasakal ang makina. Will change the uel filter this weekend.Ty sir!
    Aug 2011
    #2554
    change fuel filter and pa bleed nyo po yung sedimentor, madumi na sigurado. ganyan din kasi symptoms nung samen, palit fuel filter lang tas after non ok na ulit.
    Sent from my ALCATEL ONE TOUCH 5020E using Tapatalk now Free
    Sep 2010
    #2555
    Quote Originally Posted by bokista View Post
    Ty sir bokista! Pinalitan ko na po kanina with OEM fuel filter. Sinabay ko na rin lube change. Pina-drain ko rin po fuel tank. Ok na po manakbo. Thanks sa advise mga sir!
    #2556
    mga sir. ano po ba symptoms pag loose compression na ang engine?
    Jun 2010
    #2557
    Guys, ano gamit niyong engine oil? Napansin ko kasi when I switched to Shell helix, mas mausok ang crosswind ko (o guni-guni ko lang yun? hehe). Dati ang gamit ko Petron oil. Pero ang okay naman na napansin ko sa shell oil, less vibration. Dati kasi napapansin ko sobra alog ng manibela ko pag idle. Ano recommended niyo mga bro?
    Sep 2010
    #2558
    Quote Originally Posted by debal View Post
    With the engine running idle, try mo sir buksan ang oil filler cap. Accdg. to our mekanik, pag malakas tilansik ng langis, malamang sir blow-by na cylinder head nyo.
    #2559
    salamat sir.
    Jun 2010
    #2560
    Anyone know where I can buy aircon vents other than casa? Casa is selling a piece for 1k and I think it's too much. Plus 5 days pa makukuha. TIA
Isuzu Crosswind Owners Thread [continued]
