Sir, may leak lang yan. Mine is also 2003 model and I've done repairs too on my radiator. Nagpa-overhaul lang ako and repair with "tingga" para sa tagas. Kalokohan po iyung 4.5k na overhaul =)). Sagad na siguro ang 1500 para sa maayos na gawa. Though I can't recommend any shops for you since I'm from Cubao area. Hanap ka lang sir ng reputable shop. Madali lang yan.
Take note nga lang na sa fittings lang ang naging tagas ng sakin. Madali lang ma-repair ang ganun. The problem is, kung sa fins nga yan, ibang usapan na yun. From what my suki shop said, kapag doon daw ang tagas, maaaring palitin na nga. Better have it checked first.
magkano po bagong radiator? baka onti na lang dadagdag mo sa 4500 bagong radiator na
Good suggestion bros! I was able to have my radiator overhauled. We found out that the leak was not really from the fins. I only spent 1k for the overhaul and repair. I hope this will be a good long time fix. Been using my crosswind for 3 days now without refilling the radiator!
Had it overhauled and repaired at Prens in Alabang. Almost halfday to finish the job.
what pair of speakers ang magandang ipalit sa front and rear ng xwind xuv 03 model?? papalitan ko na kasi yung stock, pangit na ng tunog. naghahanap ako ng punchy bass replacement speaker for front and rear, 4inch sa front and 6.5inch sa rear. ayaw ko na sana lagyan ng subwoofer.
I upgraded to Sony explod. Pero sa tingin ko may limitation talaga ang speakers set-up natin. Yumayanig kasi yung pinto kaya hindi solid ang bass kahit gaano pa kalakas ang speakers mo. Unless magpa-install ka siguro ng insulation or sound deadener baka may improvement. Kaya in the end, I still resorted to an amplified bass tube para minimal lang ang space consumption. Oks na oks ang tunog niya for 6k.
ive tried the pioneer a series speakers medyo ok na ang bass para sa akin(maganda rin and presyo) just apply a deadener sa front and specially sa back....
Xwind XUV AT 2003
Pinalitan ko lang ng 4way speakers sa harap at 3way speakers sa likod (JVC 16cm).
Palit rin head unit (JVC 1DIN), 'yung may 3.5in Monitor.
Pinalagyan ko rin ng insulation / deadener... Oks na oks na ang tunog!
Talagang you can hear the difference. :thumbup:
mga boss. may nakapagparepair na ba sa inyo ng spare tire cover ng crosswind natin.. nabangga kasi yung likuran ko eh nabasag yung spare tire although maliit lang yung damage. cracked lang sa surface. pwede ba masilya at pintura lang yun? xwind '03 model po ride ko. Tia po.
Mga xwind masters, im newbie here from cebu city and just owned 2nd hand isuzu crosswind xuv 2004. May question po ako regarding sa foglamps dahil disconnected na po yong wire at gusto ko po sana e connect ulit. DIY sana po ay matulongan at magabayan nyo po ako kung paano ko gawin yon.. TIA
h3 yung lamps
na pang fog para sa xuv 04.
pano ko ba simulan?
yung unang ginawa ko, gumapang ako sa ilalim tapos sinilip at sinalat ko lang. kaya lang ang hirap! mas madali sayo kasi mataas yung xuv kesa sa xto ko na mababa.
yung pangalawa, tinanggal ko yung bumper. mas madaling procedure ito kasi kitang-kita mo yung paglalagyan mo ng bulbs sa likod ng bumper. tatanggalin mo lang naman yung 2 bolts sa magkabilang dulo tapos hatakin mo yung bumper.
pero bago mo hatakin tanggalin mo muna ulit yung clip-socket (yan ba yung pinagkabit mo sa ilalim?), baka kasi maputol.
kung natanggal na yung bumper, makikita mo na yung likuran ng housing ng foglamps.
pag natanggal mo na yung bulbs, pa test mo muna baka okay pa.
sorry ah, tagal ko na kasing ginawa ito kaya nalimutan ko na kung paano yung sa bulbs mismo. pero madali lang naman yan kung kita mo ng maayos yung housing ng foglamps.
good luck chong at sana may makatulong pa sayo!
