Page 85 of 89 FirstFirst ... 3575818283848586878889 LastLast
Results 1,681 to 1,700 of 1770
    Mar 2003
    #1681
    ^ sir we need yung mataas ground clearance nagka trauma na kasi family ko dahil kay ondoy and mas ok kung mas marami ang maisasakay na passengers and pinaka importante sa lahat ay reliability.
    Aug 2009
    #1682
    Quote Originally Posted by jeff View Post
    *jeff , Buy an xuv or sportivo. In my experienced last ondoy typhoon, naka survive sa baha 02 xuv ko. Sinubukan q agad sa baha cya (2nd used car) ncya but still powerful:sumo: specially sa flood. The water flood coming in 2 creeks(bridge) hanngang upper bumper na(almost sa isuzu logo sa grill) ung tubig(may strong current pascya.:twister3 naka survive din plus 1 flood sa main road same volume ang water.
    Aug 2009
    #1683
    Sir..
    Sino po sainyo nakapag linis na ng engine? using pressures water hoose? Ano dapat e avoid at ingatan kapag naglilinis kayo nun?
    thanls!
    Feb 2005
    #1684
    Quote Originally Posted by red16 View Post
    Sir..
    thanls!
    The alternator. Wrap it with plastic to avoid direct water hit. Aside from that, fire away! Also, if you are to clean the condenser with high pressure water, make sure you point the pressure gun DIRECTLY in front of the condenser fins. Do not attempt to clean it angled or sideways for the fins may get dented. That may result to poor cooling of your aircon.
    Mar 2003
    #1685
    ok ba aircon ng crosswind compared sa innova and adventure?
    #1686
    Quote Originally Posted by Benzmizer View Post
    Do PMS intended for 120k. That should mean drain all fluids (brake, oil, coolant, transmission/gear). Have the fan belts checked and underchassis.
    As for the water separator, pump the water out. The separator is located near the firewall (near the HVAC).
    For the water in the door, the door drain may be blocked/clogged. Have it checked and get that water out of the door to avoid corrosion.
    sir, thanks for the reply. much appreciated po. by the way, how do i pump the water out? is there something i should take off before pressing the pump? or do i press it outright?
    Feb 2005
    #1687
    Quote Originally Posted by azanza View Post
    Refer to this diagram:
    Aug 2010
    #1688
    Quote Originally Posted by fly View Post
    hello to all,
    Question regarding use of AC...
    Have you experienced stale-smelling air or "kulong na amoy" coming out of the aircon when only the blower/fan is turned on?
    This happens everytime i start the crosswind our for a drive.
    The smell disappears once i switch on the thermostat.
    The vent is shut so there's no outside air coming in.
    I got the unit this January 2010 & i've only logged 3800kms on the odometer.
    I've already sent this to ISUZU manila for a check-up since it's still under warranty.
    They couldn't give me a straight answer as to the cause.
    They've cleaned the AC but the problem is still there.
    Anyone share the same scenario? Comments, opinions, advice?
    TIA
    This happened to me. 2008 xt. Pinalinis ko lang aircon (front & rear). Ok na. nawala na amoy.
    Jun 2010
    #1689
    san k nagpalinis aircon.....
    Aug 2010
    #1690
    Quote Originally Posted by abet0202 View Post
    sa Petron San Joaquin, Pasig. Nick ang name ng aircon tech.
    Jun 2010
    #1691
    thank you sir GIBO... medyo malayo p pala sa akin. hehehe. magkano po inabot?
    Aug 2010
    #1692
    1.2k yung cleaning (front/ rear)
    1.2k din yung freon
    Aug 2009
    #1693
    thanks again sir!
    Aug 2009
    #1694
    Ok as in ok! 02 xuv skin now but still strong ac nya. Before my 05 adventure kami after 3 years nag palit nakami ng preon plus palinis... i dont know innova.
    #1695
    mga sir, were planning to get a 50k maintenance for my dads xuv02 sa casa. kaso wala akong idea about maintenance pag sa casa dadalhin, sabi nya sakin kahit isang beses daw hindi nya pa nadala yun doon since nakuha nya. my dads a very busy person kaya ngayon ako na humahawak kadalasan nito, gusto namin subukan. ang maintenance lang nito is pinapadala nya sa truck driver sa gas station for change oil, ATF and other fluids yung truck driver na ang gumagawa.
    suggestion/tips are welcome, it will be my first time, and the xuv02 too after almost 8yrs
    Feb 2005
    #1696
    Quote Originally Posted by kaioz View Post
    Hmm, since you have said that your dad never brought the vehicle sa CASA since new, i doubt it if underwent the necessary checks that a dealer does to a vehcile on a certain mileage.
    I am not that familiar on the specifics but i would suggest you perform a complete drain of fluids (every 40k mileage) -- engine oil, tranny, gear, coolant, etc. Maybe have the aircon system cleaned too (every 20k mileage). Brakes should be checked too... May need cleaning or replacement. you would not want the rotors to get damaged. Cost will become bigger. Then after that, you can follow the succeeding checks needed.
    Hope this helps and Good luck!
    Apr 2008
    #1697
    *kaioz kung ako sayo dalin mo sa casa.. magready ka lang ng pera.. pero sure naman after that every thing will be ok na.. alam ng casa kung ano ang gagawin
    #1698
    dadaan muna ako sa monday to have a job order at quote kung magkano aabutin kung ano man ang kailangan nila gawin para sa maintenance. para handa si dad at hindi magulat. $_$
    Jun 2010
    #1699
    Hi guys!
    Tanong ko lang kung anong magandang replacement wipers for crosswind. Preferably banana type. What brand, what size, how much, and where can I buy one? I bought one from Blade kasi, and it's juddering badly! TIA!
    Feb 2005
    #1700
    Quote Originally Posted by kafph2000 View Post
    Hi guys!
    Unipoint. If your wiper is juddering, you may want to explore thoroughly cleaning your windshield. mapadulas mo lang yan, mawawala yung juddering.
Isuzu Crosswind Owners Thread [ARCHIVED]
