Results 1,681 to 1,690 of 1770
Tsikot Member Rank 3
- Mar 2003
- 637
August 10th, 2010 09:39 PM #1681^ sir we need yung mataas ground clearance nagka trauma na kasi family ko dahil kay ondoy and mas ok kung mas marami ang maisasakay na passengers and pinaka importante sa lahat ay reliability.
- Aug 2009
- 349
August 11th, 2010 01:34 AM #1682*jeff , Buy an xuv or sportivo. In my experienced last ondoy typhoon, naka survive sa baha 02 xuv ko. Sinubukan q agad sa baha cya (2nd used car) ncya but still powerful:sumo: specially sa flood. The water flood coming in 2 creeks(bridge) hanngang upper bumper na(almost sa isuzu logo sa grill) ung tubig(may strong current pascya.:twister3 naka survive din plus 1 flood sa main road same volume ang water.
- Aug 2009
- 349
August 11th, 2010 01:47 AM #1683Sir..
Sino po sainyo nakapag linis na ng engine? using pressures water hoose? Ano dapat e avoid at ingatan kapag naglilinis kayo nun?
thanls!
August 11th, 2010 02:15 AM #1684
The alternator. Wrap it with plastic to avoid direct water hit. Aside from that, fire away! Also, if you are to clean the condenser with high pressure water, make sure you point the pressure gun DIRECTLY in front of the condenser fins. Do not attempt to clean it angled or sideways for the fins may get dented. That may result to poor cooling of your aircon.
- Mar 2003
- 637
- Feb 2008
- 2
August 11th, 2010 09:20 AM #1686
- Aug 2010
- 6
August 11th, 2010 07:05 PM #1688
- Jun 2010
- 20
- Aug 2010
- 6
August 11th, 2010 10:39 PM #1690
high idle RPM at engine start
