Page 87 of 89 FirstFirst ... 377783848586878889 LastLast
Results 1,721 to 1,740 of 1770
    #1721
    nag jejerk yung XUV ko when running sa 2nd and 3rd gear especially pag binibirit ko rpm hangang 2.5k (2nd and 3rd gear)...tsk tsk ano kaya problema nito?..mga sirs patulong naman...pag umaabot na sa 2.5k rpm para syang nabubulunan. kumakadyot-kadyot ang sasakyan. pa help naman...TIA
    May 2010
    #1722
    check mo pare yun fuel filter at air filter element mo, puwedeng madumi na kaya sinisinok pag-accelerate mo.
    #1723
    Quote Originally Posted by ovitrops View Post
    ok pa check ko muna, thanks
    Apr 2010
    #1724
    ano ung egr sir? eto ba ung visor?
    EGR is Exhaust Gas Recirculation
    Apr 2010
    #1725
    Quote Originally Posted by lastpogi View Post
    ah! please check the fuel system, kulang sya ng supply baka barado na ang fuel filter mo.
    #1726
    Quote Originally Posted by grandprix View Post
    ang nakakapag taka, hindi naman sya palaging ganon. pag minsan ok naman sya, pag minsan nag jejerk.
    Feb 2005
    #1727
    When was the last time you had your change oil?
    #1728
    Quote Originally Posted by Benzmizer View Post
    last june, sa isuzu alabang ko pa yun pina 25k PMS. iniisip ko, one time nag lagay kasi akong petron power booster, baka yung ang culprit. Hindi kaya?
    Feb 2005
    #1729
    Is this the one you mix with the fuel? I do the same on my MB 240D but I do not experience such. Any chance that you may have water mixed with diesel (not intentional but may be * gas station) or or it may be related to your fuel system (fuel pump/filter/etc)
    #1730
    yup eto nga yung hinahalo sa sa fuel...di bale paubos na rin naman na gas ko. try ko isagad sa tanke before ako magpa gas ulit...
    thanks sa reply, pag hindi pa rin mawala ipalinis ko na siguro fuel line nito, thanks.
    Jun 2010
    #1731
    fuel filter yan brad. Had the same experience 1 month ago. Napabayaan kasi ang fuel filter.
    Nasermonan pa tuloy ako ng mekaniko.
    #1732
    Quote Originally Posted by kafph2000 View Post
    anong gagawin sa fuel filter? linis lang o palit na? katatapos ko lang magpa PMS last June.
    Feb 2005
    #1733
    If the fuel filter is the culprit (either trace of diesel-water mixture or simply dirty), definitely replace. Main fuel filters are not designed to be cleaned.
    Now if you do find that it's either of both reasons why your fuel filter had to prematurely replaced, you better consider bringing down your fuel tank and have it cleaned too. Palinis na din yung fuel lines mo.
    May 2009
    #1734
    hello good morning fellow tsikoteers....
    have anyone of you seen or tried the new diesel from Petron it is Petron Diesel Turbo and sa Shell naman yung Shell Diesel Velocity nila...pashare naman sa mga nakapagtry na kung ano feel ang difference with the oridinary diesel we are using..thanks
    Aug 2009
    #1735
    good day! mga sir..
    \ Magkano ba usually mag pa bleed change brake fluid ng xuv natin?
    Aug 2010
    #1736
    I own a 2002 Xtrm, nahinaan ako sa stock na ilaw so nagpalit ako ng 80/100 na osram nung mga 2006. Recently napilitan akong bumalik sa orig na 55/60 kasi "nasulog" daw yung relay ko because of the high wattage of the 80/100 sabi ng mechanic ko. Ngayon naman sobrang nadidliman na ko sa 55/60, ayaw ko naman mag HID. What do you guys suggest na pamalit ko sa stock bulbs?
    #1737
    Quote Originally Posted by iwas_usok View Post
    Look for the "Osram Nightbreaker vs. Philips Extreme bulb" thread here in tsikot.
    Feb 2005
    #1738
    Quote Originally Posted by Gerbo View Post
    In addition, you should have installed ceramic sockets to regulate the increase wattage of your bulb.
    Feb 2010
    #1739
    Quote Originally Posted by red16 View Post
    good day! mga sir..
    Yong pinalinis ko brakes ng crosswind ko, kasama na pagpableed ng fluid sa Shell-Cradle, tapat ng Perpetual Las Pinas, P150 per gulong. . .
    pero ng nakita ko, madalin lang pala, pweding i-DIY. . . Sa Servitek alam ko P200 naman per gulong. . .
    Feb 2010
    #1740
    Stock wattage lang po Sir Benz ang Osram Nightbreaker and Philips Extreme. . . so there's no need to replace the socket. . .
Isuzu Crosswind Owners Thread [ARCHIVED]
