Page 125 of 607 FirstFirst ... 2575115121122123124125126127128129135175225 ... LastLast
Results 2,481 to 2,500 of 12125
    Mar 2015
    #2481
    Ano kaya top speed ng fortuner? Kasi pag lumalagpas na ako ng 140 sa Mu-X laging naiiwan na ang fortuner. Ayaw ko hamakin ang montero dahil subok ko yan sa 180.
    May 2008
    #2482
    Quote Originally Posted by JCPR20 View Post
    the reason behind why you were able to leave the fortuner at speed above 140 kmh is because of the tranny lalo na kung automatic trans na fort kasi 4 speed lang siya, from standstill up to 120 kmh mas mabilis umarangkada ang fort pero 120-140 kmh pareho na sila and 140 kmh above mas mabilis na ng konti cguro ang mux kasi 5 speed a/t siya kahit pa lower ang power and torque output niya, kaya din umabot ng 180 kmh ni fort kaya lang mas matagal niya cguro marereach un.
    #2483
    driving at 140kph? Hindi na cguro sumunod ang fortuner. baka may mahulog na naman sa skyway...
    Jan 2014
    #2484
    Hindi kasi kayo parehas ng goal. Naka set ba kayo na pedal to metal kayong dalawa? Pwedeng magkaiba kayo ng gustong cruising speed.
    Jan 2003
    #2485
    Quote Originally Posted by kutangbato View Post
    Transmission fluid ba talaga o engine oil/fluid? 1.5k palang tinakbo mo then change oil na ang transmission...
    1st pms lng yan dapat which is change engine oil at oil filter ang ginawa. Bakit pati transmission fluid pinaltan?
    Baka may na miss ako sa kwento mo bro....
    Posted via Tsikot Mobile App
    You got it right, tranny fluid ang story ni James_007. Damn tech sa casa, hindi daw nahigpitan yung drain plug nut kaya tumulo. Then again your right bakit kailangan palitan ang tranny fluid at 1.5k odo. That's pure an simple scam to increase profit by doing things unnecessary to shoot up the billing cost ng owner. That's what you call day light hiway robbery.
    #2486
    Matagal ng periodic maintenance ng Isuzu ang change ng lahat ng oil at 1500 km of use ng bagong sasakyan nila.
    Aug 2013
    #2487
    Sana I-overhaul na rin nila. Grabe naman parang new born na pina-dialysis na agad!
    Quote Originally Posted by dos2 View Post
    Maintindihan ko pa if mga 10,000kms. hehe
    Aug 2013
    #2489
    ^ Ako brod kahit 20K kms masakit pa rin sa kalooban.
    Bakit yung mga competing brands na di naman nagrerequire ng transmission fluid change sa AT nila wala namang problema? Napakababa ng rate (o halos wala nga akong nabalitaan) ng conventional AT problem na pwedeng isisi dahil hindi nag fluid change ng 1.5K kms.
    #2490
    Sa una lang naman yung change at 1.5k km. After that balik na sa normal change interval.
    Jan 2003
    #2491
    Hahaha...korek ka dyan bro, kahit Sarao o Tabing o Malaguena hindi nagpapalit ng tranny oil at that rate. Raket lang talaga being justified at the most stupid manner.
    Mar 2015
    #2492
    'Nung nagpa 1500 PMS ako regular change oil lang naman. let us know brother kung saang casa yan para hindi na mapuntahan ng iba.
    Sep 2010
    #2493
    1500 pms ako last week sa isuzu cabanatuan. Mga ginawa: change engine oil (ordinary isuzu oil, i insisted) and oil filter, tranny oil, and axle oil. Checked OK all other fluids. Total cost: P5416.
    I witnessed every job they did; talaga namang the used oils indeed looked worthy for change. Lalo na ung engine oil, parang putik ang kulay, malapot din. A finger touch indicated tiny bits parang buhangin.
    #2494
    Quote Originally Posted by janalla View Post
    Yup magaspang yan kasi break in pa at tight pa lahat ang clearances kaya recommended nila yung first 1.5k change lahat ng oil.
    #2495
    Ibig sabihin hindi nila ginawa yung standard maintenance sa rig mo. Saan casa yan para hindi mapuntahan
    #2496
    Quote Originally Posted by macsd View Post
    ako nga apat na nut sa magkabilang gulong sa likuran ang hindi nahigpitan sa Hilander XTRM ko noon pero una niyan yung bearing sa harapan. walang quality ang trabaho ng isuzu dealers
    Feb 2012
    #2497
    Malamang ojt gumawa niyan sir dun sa Isuzu isabela bago lumabas ng casa I double check lagi kung nahigpitan mga gulong
    Jan 2003
    #2498
    Get the best value from Isuzu | Motioncars
    Nabasa cguro ng IPC itong thread kaya nagpa-media outfit na sila.
    Pati mga clutch disk, pressure plates etc... na dapat eh after hundred thousand of kilometers, inilagay na nila sa PMS.
    Jul 2015
    #2499
    Mga Sir question lang po... kapag Bank PO hinde po b tlaga ksama ung Undercoating and Rust Proofing?
    Nabasa cguro ng IPC itong thread kaya nagpa-media outfit na sila. ...
    I think IPC is looking more at their facebook messages. They have almost 400k followers same as toyota facebook account. Social media reach is getting better.
    The BVP program is separate from the standardized PMS cost. The pms cost they laid out is for basic labor and filter/oil changes only.
All New Isuzu MU-X // Alterra Next Generation
