Results 21 to 30 of 96
August 1st, 2012 11:03 PM #21
Sa mga nagamit ko...ozein at yung gawa ng samsung ang the best. Bad side, they are pretty strong so take note of the warning of umi001.
Personally, I really don't care much about it (ozone) because in my belief, we are all going to die anyway with second hand smoke from yosi or from smoke pollution in our environment.
- May 2007
- 520
- Nov 2009
- 1,756
August 2nd, 2012 09:46 AM #23
These two are worth to try!
Yung tungkol sa sabon, medyo nakakatawa pero in reality tama rin na air freshener, then it will last long for sure!
Maka-damage ng evaporator? I think mas nakaka-damage pa yung mga air freshener na alcohol base
Meron ng ionizer na maliit sa bahay kaya lang di ko pansin, para kasing walang effect.
This time, I will buy a bigger one na pwedeng magamit sa room at pwede ring magamit sa car.
Additional info,
An air ionizer is a device that is intended to purify the air in a room by electrically charging the air molecules. Instead of using fans and filters to purify the air, an air ionizer uses ions to remove microscopic particles from the air. An air ionizer makes the air in a room healthier for people who are suffering from asthma, allergies, impaired immunity or respiratory ailments because fewer allergens circulate into the lungs.
Air ionizers rely on the chemical properties of particles. An ion is just a particle that is charged, either negatively or positively. Air ionizers, which can be tabletop or standalone units, create negative ions using electricity. Opposites attract, so the negative ions flood the room and seek out positively charged particles, such as dust, bacteria, pollen, smoke and many other allergens.
The negative ions and positively charged particles bond together. This creates dirt particles that are too heavy to keep floating around in the air, so they fall to the ground and can be cleaned by normal means. Some particles might fall onto other surfaces in the room, such as furniture, television screens or shelves, and can be cleaned off by dusting or wiping those surfaces.
Tsikot Member Rank 4
- 2,719
August 2nd, 2012 12:35 PM #24kung anu-ano ginagamit ko sa oto namin ... charcoal, baking soda, vinegar, lysol, glade, etc para mapanatili mabango ang amoy
nung minsan sumakay sosyal kong pinsan, sabi nya "hmmm amoy bago ah ... amoy amerika!"
lolz
August 2nd, 2012 08:50 PM #25
mothers leather cleaner and conditioner once every two weeks. after application, amoy bago na ulit
August 23rd, 2012 11:55 AM #26
- Nov 2009
- 202
August 29th, 2012 02:14 PM #28
August 29th, 2012 05:09 PM #29
August 29th, 2012 05:44 PM #30
may nabili din ako airfreshener di ko matandaan yung name pero yung hotair baloon ang itsura niya tapos isinasabit sa rear view mirror, new car scent yung amoy niya pero sa totoo lang amoy bagong laba yung upholstery yung amoy.
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
