i set the pressure to 32psi but the best ride is 28psi.
Baka naman you go so fast over potholes. You should drive normally even during a test drive, never speed up on potholes, kahit anong sasakyan pa yan, suspension will suffer or worse, the mags will get bent.
on approach of potholes, brake smoothly, as you go over the pothole, then speed up smoothly. I doubt you will hear that kalampag ever again. It's probably the tools anyway.
