Page 366 of 425 FirstFirst ... 266316356362363364365366367368369370376416 ... LastLast
Results 7,301 to 7,320 of 8497
    #7301
    Share lang.
    June 24 when I had my 40k kms PMS for my Santa Fe sa Erod.
    Brake Pads and Belts were supposed to be replaced pero makapal pa daw ang pads and the Drive Belt is ok na ok pa daw. I actually check my belts before a long drive and I can truly see na maganda pa ang belt. Wala pang himulmol or something.
    S.A. asked me kung paano daw ako mag drive kasi maganda pa daw ang preno at ang Belt samantalang yong iba daw 20k kms pa lang, palit na ng brake pad.
    Sabi ko magaang ako sa preno and I observe proper warm up before I drive.
    Ewan ko baka binobola lang ako non. we he he.
    Apr 2005
    #7302
    Quote Originally Posted by nels76 View Post
    Share lang.
    Good Job nels sir!
    BTW meron palang upgrade for rear suspension, baka magustuhan mo
    we call it spring booster pwede naman DIY
    http://www.firestoneindustrial.com/r...s/crinfo.shtml
    http://www.santafeclubph.com/forums/...?topic=236.135
    #7303
    Salamat sa offer sir.
    Nag back read ako sa SF Club Thread na 'yon to find out what is it all about.
    I can say ok na ako sa SF. All Stock except the headlights.
    I want to retain it for its soft suspension pag konti lang kaming sasakay.
    Pag heavy loads, kumuha na si erpats ng 2nd hand DMax.
    Pangbyahe ng bigas from the Province.
    Apr 2005
    #7304
    Naalala ko lang yung dating complain mo kapag loaded ka
    Anyway adjustable ang coilrite depende sa load ang air pressure na ilalagay mo. Ex, kung magaan 5-10PSI kapag loaded + - 30 naman
    Feb 2005
    #7305
    I went to Hyundai Manila Bay this afternoon and according to the SA the Hi Spec SF is no longer being offered. Can somebody verify this?
    I'm disappointed since I've already made up my mind to get this variant this december.
    May 2007
    #7306
    Quote Originally Posted by qwerty View Post
    Sir, try to talk to Sir Lyndon. He is a manager of Hyundai Manila Bay.
    If not naman, you can call Hyundai E. Rodriguez to verify... Their telephone number is 413-1848 and look for Ms. Marlyn Del Castillo. Tell her that the SFCP referred you to them!
    Feb 2005
    #7307
    Oki! Will do that tomorrow. Thanks!
    #7308
    Ang alam ko kasi Limited Edition daw yung Hi-Spec Theta II na Santa Fe..
    I might be wrong though..
    Feb 2005
    #7309
    Naku, wag naman sana...
    #7310
    as of now ZERO ang availability ng santa fe hi spec sa outsource1, di naman
    nag phase out ng unit ang HARI, pero most of the time namamatay ang ibang
    variant nya dahil biglang wala nang dumadating na stock, like the accent gls,
    getz crdi, i10 bare etc..., pero di nila sinasabing phased out na, parang ung
    getz na 1.1l na matagal na nawala pero bumalik din bigla, so lets wait and see
    #7311
    Quote Originally Posted by trackers888 View Post
    Oo pre. Yon talaga complain ko sa SF. Pang-5 Seater lang. He he he.
    Pag ginawa mong 7-Seater, nakow, parang eroplano na.
    Knowing its weakness kaya ayaw na namin sya kargahan masyado.
    Pag nilagyan naman ng Suspension gaya ng ni-recommend mo, sigurado Void ang Suspension-related Warranties pag nakita yan ng Casa.
    Pag nag-expire Warranty Sir, baka I may consider that. Pero 2012 pa yon.
    Aug 2010
    #7312
    Hi guys,
    I'm new here sa forum but been reading lots of reviews very very informative. This may be OT but I'm trying to find a second hand Santa Fe 4x2 CRDI. Anyone you know that might be selling? I tried to search the Advertisement and Buy and Sell sections but wala ako makita. Limited lang budget kaya 2nd hand muna hanap ko.
    Please move my message to the proper section if needed.
    Salamat po!
    #7313
    Guys para sa mga nag hahanap, meron pa Santa Fe Theta II 2WD High Spec sa Hyundai Dasmarinas Cavite.
    At meron sila Promo ngayon para sa Santa Fe Theta II 2WD.
    78,000 Pesos Down Payment for the Low Spec
    88,000 Pesos Down Payment for the High Spec
    If interested, kindly Call/SMS my friend SA, EJ Sibayan (0905-232-8850)
    Jun 2008
    #7314
    Hi Guys/Gals,
    Jaz wanna have your opinion sana kung anung vehicle yung mas ok if yung intended use ay yung pang harabas and occassional road trip all over luzon and papuntang Visayas and Mindanao using the nautical highway (on the Western side of the Philippines) and/or the Maharlika highway (on the Eastern side of the Philippines).
    Mas ok ba yung 2010 Hyundai Sta Fe or yung Isuzu Alterra? Kelangan ba yung 4x4 model pag yung intended use ay road trip all over the country?
    Napansin ko kasi na yung 2010 Hyundai Sta Fe na 4x4 is around Php80,000 more expensive than the Isuzu Alterra 4x4.
    As to diesel engine and transmission, everyone knows that the 2010 Hyundai Sta Fe is more advanced than the Isuzu Alterra. Pero, is it really necessary to have the most advanced diesel engine and transmission?
    Mas durable kaya yung Hyundai Sta Fe compared to Isuzu Alterra?
    How about aftersales services? Which is better, Hyundai or Isuzu?
    Alin yung may mas maraming dealership, Isuzu or Hyundai?
    TIA for your feedback
    #7315
    Pangharabas ba kamo?
    Stay Away from Santa Fe.
    Ok ang engine. Subok ko na sa Long Drive.
    But it's the suspension that I have qualms.
    Pag pinangharabas mo yan, sooner or later you will encounter squeaking suspension, whistling steering that requires replacement of Rack and Pinion Bearing, or leaking Shock Absorber.
    Knowing ang condition ng kalsada sa Pinas, you need a Ladder Frame SUV with robust suspension.
    Also, malambot suspension niya which you may find issues pag medyo loaded ka na.
    Pero if nearby Metro Manila lang naman ang trip mong byahe at di gaano loaded, ok ang Santa Fe.
    Alterra can travel farther on same amount of Fuel compared to Santa Fe and Alterra has more robust suspension.
    SF naman has the looks and comfort and a good and powerful engine too.
    So you decide.
    Mar 2004
    #7316
    guys,
    patanong naman po. sulit po ba kunin ang 2009 sta fe crdi 4x2 at the price of 1.438M while the price of 2010 facelifted version is at 1.558M?
    #7317
    Meron pa palang stock ng pre-facelift?
    IMO no... The difference is small, pero the new one has huge leaps in engine performance. Although I must say there are some things I like about the older model. I like its grill better, I like the fact that the roof rack is black compared to the new one its silver. Also mas gusto ko interior design ng luma. Nice and soft touchpoints in the door panels and the wood is not as annoying...
    Mar 2004
    #7318
    Meron pang stock ng pre-facelifted and pinag iisipan ko nga kung yun or yung facelifted ang kukunin ko...kasi 150K difference din yun e.
    i am pulling out the 300K down payment for the sorento crdi 5seaters kasi i called up the plant and indefinite talaga ang delivery...
    #7319
    Engine palang panalo na yung 2010 Facelift.
    Leather seats nalang poproblemahin mo.
    #7320
    2010 Facelift na ako.
    I can bear living without having leather seats.
    And besides, the engine ....
Hyundai Santa Fe (Gen. 2) Thread
