Page 209 of 240 FirstFirst ... 109159199205206207208209210211212213219 ... LastLast
Results 4,161 to 4,180 of 4793
    Apr 2011
    #4161
    I plan to replace the stock metal rims of my hatch to 15 inch alloys & put on 195/60 tires. Reason I chose 15's & not 17's is so not to strain the suspension & 195/60 tires since I do not like a low ride height. The alloys I am looking at has a rim size of 7 1/2 inches while the tire has a max permissible of 7 inches. Will the tires fit the wheel?
    If I may suggest, go for 185/60 instead. They are the closest in terms of overall diameter to the stock tyres. 195/60 are a little too big. I checked these using a tyre size calculator as I too plan to change the stock rims in the future.
    #4162
    Quote Originally Posted by airolynx View Post
    Thanks for the reply, bro. Actually, I already replaced the stock Kumho 175/70's which wore down after 40,000. I am currently using a 185/70/14 since I wanted a higher ground clearance. I referred to a tire sizing chart & the 175/14 diameter is 602 mm, the 185/70 is 616mm & the 195/60/15 is 615 mm, still well within the 3% allowable, so it shouldn't be much of a problem. My only concern now are the rim width of the tires & wheels & the offset. Tires are 7J & wheels are 7.5. I still have to check the offset. I hope hindi sasayad.
    Nov 2015
    #4163
    Sir/mam just recently got my accent crdi 1.6 yesterday. Wala pa 12hours binangga ako ng tricycle huhu. Buti walang dents pero scratch meron. Anyway my concern is sa first PMS ko change oil na ba agad? Un kasi sabi skin ng hyundai. Nagtataka ako kasi ung Mazda 3 ko aft 10k pa ung fiest change oil.
    Feb 2010
    #4164
    Quote Originally Posted by Krisace View Post
    I've gone through several new cars already and i make sure my first oil change is at 1,000km. my reason for this is that i wanted to get rid of all the gunk and metal shavings that inevitably gets shaved-off from a tight new engine. I usually make use of mineral (dino) oil during my 1st 1,000km.
    then all my diesels engines get oil changes every 5,000 km thereafter using fully synthetic oils (sometimes semi-synthetic if naubusan ang local supplier ko ng fully synth).
    #4165
    Sorry to hear that bro. Kung ako yan, di ako makakatulog. Kung hindi naman nag chip off yung paint, this might help: try to blend in the scratch using a cleaner wax (do not use a scratch remover or a rubbing compound) like Microtex Nano Fil, then seal in the wax with Microtex Nano Sil. These come in sachets, which I guess will be enough, & is the cheapest you will find. You can also use 3M cleaner wax or any cleaner wax. Di yan mawawala on the first try, but in time, will heal by itself.
    Jun 2008
    #4166
    You still need to level the scratches with fine sand paper say 1500 grit & finish with polishing compound bago mo e nano fil & nano sil for better result.
    Jan 2016
    #4167
    Good day po mga sir. Meron na po ba sainyo ang naka 2016 accent hatch na 7speed dual clutch transmission? Kamusta po performance?
    Oct 2015
    #4168
    Quote Originally Posted by axelightning10 View Post
    ok na ok po sir..
    Feb 2010
    #4169
    Quote Originally Posted by kircchoffs View Post
    ok na ok po sir..
    how does it compare to driving a manual tranny car. mas feeling "automatic" ba sya (parang may hesitation pag gusto mo umarangkada) or mas "manual" ang response nya (ala-YES MASTER! pick a gear and watch it go)?
    Oct 2015
    #4170
    di ko po masabi yung feeling automatic na tinatawag kasi galing po akong owner type jeep. pero sa arangkada mabilis po kasi ilang secs lang nasa 7th gear na ako ang bilis mag change gear.
    kung gusto mo namang feeling manual may shifter naman po + - kayo nang bahala mag change gear sa gusto nyong rpm. mas lalong pong mabilis arangkada kasi wala nang apak ng clutch.
    Feb 2010
    #4171
    NICE! cant wait for my scheduled test drive for the 7-speed DCT accent.
    Dec 2015
    #4172
    Guys, ptp im Selling zic oil 5w30 diesel full synthetic for modern crdi. Meet up lang po ako around alabang and laguna area. For those interested, Txt me up 09193114233
    Jan 2016
    #4173
    Quote Originally Posted by weisshorn View Post
    IMHO No problem at all.
    Pag naghalo yung Fuel Save at V Power mahina yung hatak at parang nacho-choke yung engine siguro kasi halos 50-50 yung ratio
    Jan 2016
    #4174
    Sir 185/70/14 hindi po ba sasayad? wala po ba kayong naencounter na problem?
    #4175
    Quote Originally Posted by Allan Esposo View Post
    Sa 185/70/14, walang problema. hindi naman sumasayad sa shock mounts at bumper. sufficient rin ang height kasi di na sumasayad sa humps. Sa alloy wheels naman, hanggang 6.5jj lang talaga pwede width para di sumayad at umusli.
    Jan 2016
    #4176
    Ok sir magpalit din ako ng gulong pag medjo pudpud na sumayad din kasi yung accent ko last Sunday nung dumaan kami sa Bangui
    Jun 2015
    #4177
    Pasensya na sir makikisingit lang ako dito sa thread ng mga accent Hatch owners. Wala ako iba makita similar thread. If OT just let me know.
    Does the hatch and sedan have the same diesel engine? Ergo same fuel consumption ba sila? Comparatively mas lower priced kasi si sedan and was wondering what the major difference are in the features aside from one is a hatch and the other a sedan?
    Oct 2015
    #4178
    same engine lang po sila sir. sa fuel eco mukhang mas lamang si hatch kasi magaan. wala po yatang airbag yung pasenger ng sedan, wala rin yung ibang safety features na abs at ebd. tapos yung magkaiba na rin po sila ng headlight, naka drl na po yung hatch. so far yan lang po naalala ko bago ko ma finalize na hatch ang kunin ko.
    plus factor na rin yung porma, compartment size at ease mag park 😀
    Jun 2011
    #4179
    ️Sir how do I turn off ECO mode... ? Accent hatch
    Jun 2011
    #4180
    Ok na sir.. Sa trip meter pa na on and off
Hyundai ACCENT Hatch CRDI 1.6
