Page 219 of 240 FirstFirst ... 119169209215216217218219220221222223229 ... LastLast
Results 4,361 to 4,380 of 4793
    #4361
    Quote Originally Posted by lucky gfg View Post
    Salamat sir sa info. Ask ko lang din ilang kilometer po ba palit ng gear oil sa hyundai accent hatch crdi 2015? Godbless...
    Transmission oil? Kung under warranty, sa Casa every 40k. Pero at 80k, di naman nila pinalitan.
    Jun 2016
    #4362
    i got my accent crdi sedan! holy s*** ang lakas ng hatak, bilis nagulat ako sa inclined hill na mataas di na ko umaapak sa gas, clutch lang apat kami sakay swabeng swabe hehehe
    Apr 2009
    #4363
    Quote Originally Posted by kevinXYX View Post
    congrats enjoy your new ride sir
    Sent from my GT-I9300 using Tsikot Forums mobile app
    Jul 2015
    #4364
    Whats your top speed?
    Jul 2015
    #4365
    Ahh, sorry for asking that, kakalabas lang pala sa kasa.
    #4366
    That is why you cannot drive it like a gasoline powered car. When you drive it while it is warming up in the morning, you don't even have to press on the accelerator. You can just shift & it accelerates. Sometimes, when you downshift to engine brake, the car will accelerate instead. You will have to mind your speed. The car revs so low that before you know it, you are at 100 kph already. Be careful over humps.
    Jun 2016
    #4367
    ^thanks sir i will keep that in mind, okay lang ba istart ko yung sasakyan from cold start then gamitin ko lang yung clutch para pausugin ko yung sasakyan ng onti? hindi kasi makadaan yung motor ng papa ko sa garahe need to atras ng onti, im not revving it just clutch, hindi naman makakaapekto sa turbo pag ganung case?
    #4368
    Oo naman
    Jun 2016
    #4369
    huhuhu pano kaya to matatanggal?
    #4370
    collect a few more, before re-painting it. "dadami pa yan."
    Jun 2008
    #4371
    Just slightly rub with rubbing compound para medyo pumantay ang gasgas then wax. Masasanay ka rin na meron dyan 😂😉
    Sent from my Lenovo A7000-a using Tsikot Forums mobile app
    Jun 2016
    #4372
    Mga sir ano po bang dapat na grades na transmission oil ang gagamitin para sa accent crdi 2015 naten?
    #4373
    you can source some touch-up paint or any white, non-water-soluble paint for that matter, and apply with a small brush to conceal the obvious.
    then, after you have collected a sizeable number, you can have the entire bumper re-painted.
    it's plastic, sir. it won't rust.
    Jun 2016
    #4374
    Quote Originally Posted by weisshorn View Post
    Just slightly rub with rubbing compound para medyo pumantay ang gasgas then wax. Masasanay ka rin na meron dyan ����
    i can't stop staring at it sir, hopefully matigil na ako sa kakaisip hehehe
    pumunta agad akong ace hardware bumili ako ng car scratch pen hindi ko pa natatry if gagana siya nakagamit na kayo ng ganun sir?
    also any tips on how to clutch control with this car? kasi pag sa heavy traffic and inclined hills ginagawa ko pag aandar na yung nasa harap ko clutch->first gear->slow release clutch-naka semi depress yung clutch->no gas->car is moving na, then pag nag break yung nasa harap ko depress ulit yung clutch->break-> then back to neutral (im worried about clutch wear out am i doing it right?), natatakot kasi ako baka pag ni irelease ko yung clutch then it might accelerate fast at tamaan ko rear bumper ng nasa harapan ko (ang lakas kasi ng hatak nabibigla ako) in result minsan naka fully depressed-semi depress ako sa clutch at hindi ako nag gagas sa heavy traffic bumper to bumper i'm a newbie driver.
    Feb 2010
    #4375
    find an incline road with no other cars. a long steep driveway will do. Keep practicing hill-start stop and go driving til it becomes second nature to you. lahat yan nakukuha sa practce lang. madaling magbigay ng tips pero everything you read will be thrown out of the window when its the actual thing na. PRACTICE, PRACTICE and MORE PRACTICE.
    Jun 2016
    #4376
    Quote Originally Posted by glennhmd View Post
    mali yung ginagawa ko sir glenn? i will practice more.
    Jun 2008
    #4377
    Tama naman sir kaso kung madalas ka naka half-clutch e mapabilis nga ang wear ng clutch disc. Distancia ka na lang sa sinusundan mo. And yes, practice is your best tutor. Don't worry di naman agad agad maubos ang clutch disc. May isang car ako dati 3 ang nag aral at natuto mag drive about 4 years after binaba ko ang clutch assy good pa ang clutch disc & pressure plate.
    Jun 2016
    #4378
    ang problem ko sir weiss kapag nakuha ko na yung biting point i dont want to release the clutch fully kasi ang bilis niya mag accelerate pa abante baka mabangga ko yung harapan ko although sabi mo nga distancia lang pero binubusinahan na ko sa likod kapag pinalayo ko masyado yung sa harapan ko, i fear na baka mabangga ko yung harapan ko, i want to know paano ginagawa niyo sa heavy bumper to bumper traffic sir
    #4379
    pag sa traffic, apak sa BRAKE at clutch, release brake & simultaneously release clutch a little with right foot nakaabang sa accelerator pedal. lalaruin mo lang yung clutch pedal to get desired speed, tapos accelerate more if needed, if not, depress clutch, BRAKE & put in neutral, release clutch. As for clutch wear, it will probably take you ten years before you will ever need to change the clutch disc & contact plate.
    Feb 2010
    #4380
    Tama naman gingawa mo bro. We've all been there at your stage right now. Yun feeling every move kailangan pag-isipan. Like what the others have chimed in, timpla timpla lang ng clutch brake and gas ang kailangan dyan sa ganyan situation. How much you release your clutch and the timing of gas and brake is like a symphony if sanay ka na. Listen and feel the engine. You don't even have to think about anything. You get there by practicing with your car. It's only during actual usage of your particular car is when you find her sweet spot. Ika nga kung asan yun kiliti nya. .
    Just make sure you don't practice where you might cause an accident.
Hyundai ACCENT Hatch CRDI 1.6
