Page 211 of 240 FirstFirst ... 111161201207208209210211212213214215221 ... LastLast
Results 4,201 to 4,220 of 4793
    Dec 2014
    #4201
    Bro, ganito sabi sakin ng mechanic sa Hyundai Las Pinas, kung saan ako nagpapa service. Kung sakali raw na magpapalit ka ng wheels (alloy), itago mo yung stock metal rims & tires. Sa off chance na magka problema yung suspension mo, ibalik mo pansamantala yung stock wheels & tires bago mo ipa service. Marami raw silang nakikitang naka wheel upgrade pero under warranty naman at yung mechanics di naman nagsusumbong.
    Update lang, tinawagan uli ako ng hyundai las pinas crm dept, pasok daw sa range yung 195/60r15 so hindi daw mavvoid yung warranty. Kelangan lang daw sa kanila ipakabit yung new tires. Bakit kaya? Pero mas gusto ko yung suggestion mo bro bloowolf. Ganun na lang gagawin ko
    Feb 2010
    #4202
    Quote Originally Posted by simpl3_athan View Post
    agree ako dito bro. dont ever give a single reason, however small, for them to decline your warranty claims. use your new alloy rims and wheels, then pag may problema, balik na lang to stock wheels bago dalhin sa stealership.
    Aug 2007
    #4203
    Mga sir need your help. Im planning on getting a used Accent hatch A/T. Are there any differences between 2013 and 2014 models? I also noticed some have foglamps/body colored door handles tapos yung iba black handles/no fogs/steel rims lang. TIA
    #4204
    Quote Originally Posted by GunnerJam View Post
    If I may, as far as I know, there is no difference between the 2013 & 2014 model except for the logos on the hatch area. In the 2013 model, it says Hyundai on the left & Accent on the right. In the 2014 model, it says Accent on the left & CRDI on the right. The 2013 & 2014 models sport body colored door handles, which is your clue if the model is a 2013/14. Also, the 2013/14 sports all discs & have a center console & steering wheel audio controller. The 2015 models sport drum rear brakes. The 2013/14 AT models all come with 16" alloys & foglamps while the MTs all have 14" steel rims with no foglamps. All 2015 MT & AT basic models have black door handles with 14" steels. This is as far as my knowledge of the hatch goes. Good luck.
    Feb 2010
    #4205
    Nice info sir. Pansin ko lang, bakit parang nag downgrade ng specs from 2013/2014 compared to 2015.
    Even the 2016 model eh naka-steel rims na lang din. Also front disc-rear drum na lang din ata ang brakes ng 2016 model. Wala din steering wheel audio controls. Parang mas sulit yun 2013/2014 models. Same engine pa din naman.
    Aug 2007
    #4206
    Thank you sir! That was really helpful. Does the accent diesel have any common defects? Like yung civic FD dati defective yung engine support. I want to know kasi para pag nagtingin ako ng unit alam ko kung ano yung mga ichcheck/papakinggang tunog. Thanks again!
    #4207
    Like what bro airolynx said, check for oil leak in the air filter box. Other problems are steering column noise. It also should not be spewing smoke at idle or when running.
    #4208
    Quote Originally Posted by glennhmd View Post
    Mas sulit talaga yung 13/14 models dahil dun sa discs, abs at ebd; although wala syang projector lights at 2 din head unit, pero overall, maganda pa rin kasi masarap imaneho at super tipid. It's a good buy. Yung unit ko, a 2014 model, is now running 76k kms but still feels new. Iba na rin gawa ng Hyundai ngayon, unlike those of yesteryears.
    #4209
    Sir bloowolf. At 76k kms na egr cleaning na ba ng casa during pms or no need na?
    Aug 2007
    #4210
    If I do find traces of oil sa air box, ano solution dun? OCC? Sa steering column noise, what exactly is wrong with it? Sorry daming tanong. I just want to be sure pag nagtingin ako ng unit. TIA!
    #4211
    It's a second hand unit, so I'd most likely look for another car I can get that is still fresh.
    #4212
    Quote Originally Posted by valskie01 View Post
    Pagkaalam ko, they won't unless there is a problem like excessive fumes, which they will clean for free. f you request for it, cleaning the egr, along with the whole exhaust system, including the cat con, will cost you P4,500 at least. They cleaned mine when I had a problem at 15k kms.
    Nov 2015
    #4213
    Guys need your expertise. Its my 1k PMS. Sabi sakin change oil and oil filter. Ano recommend nyo na type ng oil? Mga how much kaya abutin first pms ko. Thanks!
    Feb 2010
    #4214
    Quote Originally Posted by Krisace View Post
    1K PMS is free labor. Just pay for oil and oil filter. Use fully synthetic or at least semi-synthetic oil.
    Oct 2015
    #4215
    naka Euro 4 na rin ang Total, may nakapag try na po ba?
    Apr 2012
    #4216
    Quote Originally Posted by kircchoffs View Post
    Euro 4 na lahat
    Feb 2016
    #4217
    Any reviews or feedbacks para sa 2016 Accent Hatch A/T DCT Diesel? Thanks
    #4218
    Sa Total, ang magandang diesel nila yung Excellium. Yung regular diesel nila last year mabula. ewan ko lang ngayon. Ayoko kasi ng mabulang diesel
    #4219
    It's the same diesel, just with different additives. Bubbles could be just because of the dispenser pumping too quickly.
    #4220
    Nah, top quality diesel isn't foamy.
Hyundai ACCENT Hatch CRDI 1.6
