Mga sir madalas po sumasayad sa humps ung hatch ko lalo na pag mejo malapad ata mataas ung humps. Masosolve po ba to ng o-sulee spring cushion? If yes sa harap lang po ba maglalagay or front and back? Thanks po
Hindi po maso-solve ng O-Sulee 'yan. Either use bigger tires (i.e. from 14 to 16), or learn to do the S-maneuver when crossing your car through humps. This is coming from an Accent owner that already has O-Sulee installed on all fours.. akala ko kasi malulutas ng spring cushion yung issue ko with rubbing sa rear wheels pag naka 17, palit goma pa rin pala talaga kailangan mangyari.
Mas madalas yan pag loaded ang sasakyan on stock 14" wheels. Currently may 2 sets ako na gulong, 17" na 215x45 at 14" na 185x65 (I seriously wish common ang 70 series na tires for this size, unfortunately hindi so had to make do with 65).. walang kasayad-sayad sa 17", pero ang dalas sumayad ng pang-ilalim ko on 14", though no choice ako pag long drive yun talaga gamit ko dahil mas matipid sa gas at iwas bengkong as compared sa 17".
Okay update lang dito guys. I went ahead and sent a complaint to HARI using their Voice of the Customer and I was surprised mabilis yung action nila:cheer2:
This is their reply to my complaint:
"Please be informed that we have already brought the matter to the attention of your servicing dealer for their immediate and appropriate action. We have also requested their Top Management to investigate the matter and come up with corrective measures to preclude similar incidents.
We also wish to inform you that the recommended oil drain interval is 5,000 kms or three months, whichever comes first. When fully synthetic HGMO is used, the drain interval may be extended to 10,000 kilometers, with top up at 5,000 kilometers with oil filter change. "
That clears it.![]()
Nung stock tires pa naka kabit (175/70/14), laging sumasayad akop sa malaking humps lalo na kapag maraming kargada. Yung 175/70/14 tires may diameter na 602mm. Pinalitan ko ng 185/70/14 na may diameter na 616mm. may difference sila nna 14mm na significant enough para hindi na sumayad sa malalaking humps. although paminsan-minsan sumasayad pag mabilis masyado takbo ko sa humps, naminimize na rin.
Bros,
Anong size ng tool ang ginagamit para makalas yung oil filter cartridge?
Planning to DIY ang pagpapalit ng oil filter element.
Thanks
the oil filter cartridge of my non-hyundai car and of most other engines i know, might be removed by twisting off with the hand.
for tighter ones, an oil filter removal tool is available. "one size fits all".
i have seen mechanics punch the filter cannister thru using a screwdriver, and twist it off using the skewered 'driver.
yung oil drain plug ang may size...
good luck, po. happy draining.
Di ko nakita actual ng 1.6L U2 crdi oil filter ng accent. Might be the same size to that of Caren's 1.7L U2 crdi engine which is 27 mm socket wrench.
Top-up lang po sana gagawin ko and change oil filter kaya DIY na lang sana.
Hindi ko na ipapasok sa casa/non-casa, mapapamahal lang ako eh madali lang naman yun.
Wala po kasi ako socket wrench kaya bibili pa sana ako nung correct size na pwede magamit, try ko nga po yung 27mm.
Thanks po.![]()
Mga sirs may naka experience na po ba sa inyo ng ganito minsan nag lock yung susian ng sasakyan as in hindi mapihit para mag start yung makina
Twice na po nangyari sa akin yun Hyundai Accent 2016 Crdi po pala yung sasakyan ko
