Page 337 of 404 FirstFirst ... 237287327333334335336337338339340341347387 ... LastLast
Results 6,721 to 6,740 of 8077
    #6721
    GS short name for Grand Starex
    Gold Limited afaik, top of the line model ng starex.
    VGT - latest technology on turbos which stands for Variable Geometry Turbo. Hyundai was one of the first to implement this into their production cars at least in PH.
    SG? Singapore? Hehehe
    eto pa alam ko:
    TCI: new body but still using the old engine from the previous generation
    Jun 2012
    #6722
    eto pa alam ko:
    SG super grandia. Kalaban ng starex hehe
    Yung Gold, local unit. Pag gray market CVX or HVX. Mas marami features ang gray market
    Sent from my SM-A9000 using Tapatalk
    #6723
    Ubos ang preno, inabot ang indicator. Wahehe!
    Kayo ba?
    Bro.,- replaced my front brake pads at 20KKm.....
    Grabe!
    _/_/_/
    31.3K _/_/_/_/_/_/_/_/_/_/
    Nov 2007
    #6724
    Guys, manual says to replace rear axle oil at 90k kms. Where do we buy the rear axle oil na API GL-4 SAE 90? magkano rin inaabot sa labor?
    Apr 2012
    #6725
    Quote Originally Posted by JJB View Post
    I just had mine sa Servitek. Mura lang yan.
    Sent from my LG-H818 using Tapatalk
    Nov 2007
    #6726
    Tamang tama at servitek ko papadala talaga ang GS. May kalampag ng konti na rin. Hope smooth ang byahe namin to Baguio after Xmas
    Nov 2007
    #6727
    Better ba ipa-blank ang EGR natin?
    Apr 2012
    #6728
    Just use sae90 GL-4 oil. You can find those in shell or Caltex.
    Nov 2007
    #6729
    Thanks sa replies.
    May new problem si GS. Low power sya sometimes and Hindi makaakyat sa inclined roads minsan. Napalitan na fuel filter and ATF fluid. Nadala na rin sa casa and walang errors naman sa GDS scan nila. Reset ng ecu lang ginawa. Nag lowpower na naman this AM.
    Ano pa kaya possible fix?
    Oct 2015
    #6730
    Thanks sa replies.
    Mausok ba? Sounds like clogged air filter or egr.
    Nov 2007
    #6731
    Quote Originally Posted by Wh1stl3r2 View Post
    Hindi nga mausok eh. Just changed the air filter too. Gusto ko na nga ipa-blank ang EGR
    Oct 2015
    #6732
    Minsan kasi di kita yung usok, pag under heavy load lang yung engine like uphill from standstill. You could try blanking egr, if problem goes away, yun na yun. But also look at the intake while you're at it baka nabarahan na ng soot.
    Nov 2007
    #6733
    okay will do that. Hoping hindi turbo or something big ang problem. Thanks for the help. Will update this thread
    Oct 2015
    #6734
    Don't fret bro, kung turbo yan makapal ang usok. Also maputi na bluish ang smoke. Member na din ako ng basag turbo club 😵
    You could get your blanking plate from sir zix. When you have it installed make sure walang singaw by putting some soap bubbles on the area when it is running. Kung meron you can put liquid gasket on the outer edges.
    #6735
    kung turbo yan kahit sa humps hirap umakyat nyan. saka maitim ang usok pag turbo/turbo hose ang problema. black-bluish smoke pag tagas na bearing ng turbo.
    #6736
    Planning to replace my HVX with another Starex. Pero sobrang mahal na ng mga grey market units. 2.1M up.
    Question lang sa local units, ano ba ang dinagdag or nabawas sa mga features ng mga newer models?
    Signature
    Oct 2015
    #6737
    *boybi
    Sir why are you selling your old HVX? Have you considered the 11 seater Grand Carnival?
    #6738
    *boybi
    Matanda na. It's already 7 years with almost 140K kms on the odo.
    I need the space of the Starex. Malaki ang cargo space nya even with 8 passengers sitting comfortably.
    I also have a Toyota Sienna, so out of the equation na ang Carnival.
    Ayoko naman ang Hi-Ace or any van with engines under the seats.
    Signature
    Oct 2015
    #6739
    I see. The only major difference I could think of would be Euro 5 compliant engine compared to the old Euro 4 GS. Seats and everything else look like they are the same.
    #6740
    the front grill. wala, hangang cosmetics na lang hehehe. pati head lamps di man lang magawang projectors e.
    wala ba talaga lalabas na all new starex?
2008 Hyundai Starex (Gen. 4)
