Page 295 of 404 FirstFirst ... 195245285291292293294295296297298299305345395 ... LastLast
Results 5,881 to 5,900 of 8077
    #5881
    The key is to find a high-wattage white bulb that is of the same type that will fit the socket for your signal light. This will be your new reverse light.
    And the same is true,- find a yellow bulb that is of the same type that will fit the socket for your reverse light. This will be your new signal light .
    Open up the tail light assembly; Swap the wirings; Insert the new bulbs; Put back the tail light assembly.
    Good opportunity for those who are HARI units- to also modify their tail lights (park lights) to be the same as grey market units.... Note that one pair of your tail light bulbs are already double contact bulbs, and the sockets are meant to be double contacts,- so you need to buy only another pair of double contact bulbs and another pair of double contact sockets.
    Pull out the lone connector from each of one pair of the sockets; Re-insert these connectors to the other pair of sockets- you now have one pair of double contact sockets from your original sockets; Replace the first pair of sockets with your newly purchased double-contact sockets; Rewire for double contacts all 4 tail lights with double contact sockets and double contact bulbs. Done!
    “The measure of a man is what he does with power – LJIOHF!”
    24.7K:luvmenot:
    #5882
    Hehehe! Actually, di naman ako bitin sa ilaw ko. The camera is working quite nicely with the stock reverse light and is a big help, though the angle could have been better.
    An upgrade of the reverse light might be a workable solution -- the quick one with a stronger LED bulb, or the ultimate one your solution.
    Pano nagkasya yung H4 sa signal light area? I mean, how were you able to lock it in?
    #5883
    Bro yebo could have changed the socket to an h4....
    #5884
    Make the hole bigger then screw an h4 bulb holder. Or you can do the easy way which is make the hole bigger and stick it in there using silicone sealant (which is how it was done the first time ). It will not look professional but nobody sees it anyway.
    #5885
    Bro.,- did you change the fuses(power rating) particular to those bulbs?
    24.7K:luvmenot:
    #5886
    45 psi max lang, matagtag na nga pag 47 psi e.
    Agree. 45 psi should be good enough.
    #5887
    Hmmm... pwede!
    I assume the sockets for the original reverse and signal can be swapped without mods?
    Apr 2008
    #5888
    Just sharing what I saw in TGP. Hyundai's version of Alphard.
    Hyundai Grand Starex Gold now has Premium and Platinum variants
    By Dinzo Tabamo — 18 Oct 2014
    At a literally star-studded launch last night, local Hyundai distributor Hyundai Asia Resources Inc. introduced new variants of its popular Starex van. There are two actually, and they’re called the Grand Starex Gold Premium and the Grand Starex Gold Platinum.
    The event was held at the Hyundai Parañaque West dealership, an establishment known to have actor Dingdong Dantesas one of the owners. Several showbiz personalities were seen present, most likely Dantes's friends in the business.
    But to us, of course, the car is still and always the star--or the van in this case.
    As their names imply, the Grand Starex Gold Premium and the Grand Starex Gold Platinum have been fitted with aesthetic and creature-comfort upgrades. On the outside, they have a new chrome grille, body-colored side mirrors, new 16-inch alloy wheels, and new front and rear bumpers.
    Inside, passengers will enjoy plush beige leather seats configured for only nine people. There are second-row captain's seats that are available only in these two variants, giving their occupants generous legroom to relax in.
    It is in the toys that these two variants differ from each other, but not by much. The Gold Premium spec has a 6.5-inch screen and two nine-inch headrest-mounted monitors for TV-marathon-loving passengers.
    The Gold Platinum edition takes in-car entertainment to another level. Behind the driver is a 22-inch LCD screen that--get this--retracts mechanically down into a receptacle when not in use. When the kids want to watch Kung Fu Panda, the monitor raises up again via a hidden motor. It’s a little James Bond actually. A high-fidelity sound setup accompanies the retracting screen.
    The prices for the new vans are:
    Grand Starex VGT GLS AT Gold with Premium package - P2,368,000
    Grand Starex VGT GLS AT Gold with Platinum package - P2,588,000
    Those figures are higher than the most premium Toyota Hiace, but significantly lower than the Lexus-like Toyota Alphard. This is interesting positioning from HARI.
    We can only imagine how comfortable these Grand Starex variants are in gridlock. Once people start making reservations, we're betting it will be a good holiday season for Dingdong Dantes and the other HARI dealers.
    Photos by Dinzo Tabamo
    Here is the link: Hyundai Grand Starex Gold now has Premium and Platinum variants | TopGear.com.ph
    #5889
    Pataas ng pataas....
    Apr 2012
    #5890
    May nakapg palit na ba ng ATF sa inyo? Malapit na ako mag 40k kms. Sabi sa akin ng mga kilala ko palit ATF daw un?
    Ano ba madalas ginagawa sa 40k PMS?
    #5891
    Major PMS yan, palit lahat ng oil, engine oil, power steering fluid, atf (sweetening) , brake fluid. I paid 25k, with discounts nayan. Hyundai North EDSA. Inabot ng 5 hours kahit pasok sa Jet service nila.
    Aug 2011
    #5892
    Hello. May brand in paticular ba na battery na kailangan gamitin sa grand starex?
    TIA
    #5893
    Quote Originally Posted by spat View Post
    TIA
    Wala naman particular brand na battery ang kailangan para sa GS. Pero in my experience, Amaron ang magandang brand ng replacement battery these days.
    #5894
    Quote Originally Posted by ronw123w124 View Post
    Hmmm... Must keep Amaron in mind for my next round of battery changes. Hopefully, though, di pa naman.
    Mga magkano pala ang para sa GS?
    #5895
    3SM amaron nasa +/-5,500 without trade in.
    #5896
    Pwede na! Thanks!
    #5897
    Just realized that my Motolite Gold is going on 21 months already. I noticed there was a split-second lag in starting after not having used the car for 3 days. I assume this is about as long as the warranty goes for Motolite gold, right?
    #5898
    From what I know, 21 months ang warranty ng Motolite Gold. In my experience, the battery dies around a month or 2 after the warranty expires. I'm also running Motolite Gold on my GS, the original 4 year old Korean battery was still going strong. I only replaced it because my parent's 2005 GRX was up for sale and the Motolite Gold in it was just 3 months old, so I swapped it with my old battery.
    Aug 2011
    #5899
    Ok thanks.
    Was thinking of outting Amaron kung sakaling kelangan nang palitan. Amaron kasi pinalit ko dun sa isang auto although 2sm lang yun. Di ko din sure kung may mas malaki pa dun. Now i know meron pala. Ty ulit.
    #5900
    Yeah, 21 months din lang ang alala ko sa warranty ng Motolite Gold. So I'm 21 months and 8 days already -- warranty gone. Let's see when it gives out.
    The original one lasted about 25 months, IIRC. Nga lang, I was out of town when it called for a replacement, kaya ayun, forced to buy a Motolite.
2008 Hyundai Starex (Gen. 4)
