Page 11 of 18 FirstFirst ... 789101112131415 ... LastLast
Results 101 to 110 of 180
    Apr 2014
    #101
    Nice information. Try ko later. Thanks!
    May 2015
    #102
    Great info.
    Jul 2015
    #103
    Sir ask q lng po newbie s honda car kse mali dw po nailagay q na atf oil shell apirax po oil na nirecommend ng mekaniko nmin pero as per may tropa dpt dw pg honda mas mgnda dw atf Z1 or cvtf dw dpt oil n ilagay q a transmission. Worried lng aq bka masira ung transmission q sa nilgy q na oil. Pero balak q drain at palitan agd dis week ung atf oil ng cvtf or atf z1 ng honda. Ok lng po ba yun sir nalagyn q ng maling oil.tnx
    Aug 2013
    #104
    Quote Originally Posted by mykel04 View Post
    Kung Honda CVT transmission ng sasakyan mo recommended, from any site, is to use authentic Honda CVTF, as this version of Honda CVT is sensitive. Don't risk it to avoid expensive CVT failure wherein you will need to have it replaced to fix. This is for Honda City and Jazz CVT.
    Pero kung standard transmission lang ok naman yata kahit third party ATF.
    Feb 2015
    #105
    Dapat sir CVT Fluid (CVTF) kung naka CVT ka, marami na nasirang tranny dahil atf lang nilagay sa cvt. Better replace it immediately kesa masira cvt mo, sakit sa ulo at sa bulsa yan pag nagkataon.
    Change asap.
    Lots of damaged cvt because of stupid mechanics using regular atf fluid.
    Owners manual includes which fluids to use. Owners should read it. Hence owners manual.
    Cvt oil change interval nasa manual also. Every 20k?
    Pag kakachange mo lng after 75k.. of course meron na possible damage.
    #107
    Quote Originally Posted by e2romo View Post
    Kahit yung Honda AT cars, medyo mapili sa ATF. May mga cases na yung iba gumamit ng third party ATF on a Honda AT car tapos nag slide yung tranny. It is better to use Honda ATF just to be on the safe side.
    Sep 2009
    #108
    Uy! mukhang may bagong member kami sa group. Welcome sir! PM mo lang ako pag need mo replace tranny mo ha. He,he.
    Drain it ASAP and change the fluid. Use only recommended CVT Fluid by Honda. If wala ka pa budget pangpalit CVT, wag mo muna gamitin auto mo or even start the ignition. Malaki laking sakit ng ulo ang naghihintay sayo pag nagkataon.
    Jul 2015
    #109
    Sir maraming salamat po ahhh.. s advice. Salamat din po s wc. Oo nga sir palitan q agd kakatakot mas malaking gastos pgnagkataon. Tnx ulit.
    Jul 2015
    #110
    Sir last question po sir ung po bang gearbox oil un po ba ung cvt na oil? Honda jazz vtec 2006 model A.T po pla sskyn q.
Honda Jazz/City CVT Reset Procedures
