Results 31 to 40 of 62
- Feb 2018
- 65
September 3rd, 2018 02:59 AM #31Hi all, like I said the engine mounts are all new.
1 on the left side under the battery, 1 on the right top and then one for the transmission. In total all 3 have been put new. Based on the scanner, the car idle at 600-700rpm. Which is fine. When the air con compressor kicks in, the rpm goes to 900 which is also fine. But problem is that the car is vibrating alot. Just but pressing a little gas to 100 rpm more, the car smoothes out... I believe that somehow, my car needs to increase 100rpm + value and it will be perfect. But problem is how? Everything is adjusted through the computer box and no manual adjustment is available....
September 3rd, 2018 10:05 AM #32
Did you use original engine and transmission mounts? ... Replacement mounts are not very effective at absorbing vibration ... Also, did you replace all the mounts? ... If not all are replaced, it will also cause vibration ...
- Feb 2018
- 65
September 3rd, 2018 03:34 PM #33
September 3rd, 2018 04:05 PM #34
OEM Engine Mounts are water filled rubber mounts. While replacement are rubber only. Make sure you buy OEM.
- Jul 2017
- 102
September 3rd, 2018 04:10 PM #35There are 5- mounts.
>Front right (passenger side)
>Upper torgue mount (passenger side) - connected to Front right mount
> Lower torque mount - bottom part of engine
> Transmount
> Diffmount
BTW, did you check the 3-mounts that you replaced if really they have damaged/cracked?
Try to run your engine at idle and observe which portion does shows strong movements.
Probably, the mount nearest to it may have a problem. If any strong engine vibration
on the passenger side, check the bracket connecting the engine and the Front right mount,
co'z sometime "lubog" na at metal bracket already touching that no more rubber part
isolating the engine and car body.
- Feb 2018
- 65
September 3rd, 2018 06:26 PM #36
September 4th, 2018 10:05 AM #37
Always change all engine mounts at the same time ... Some mounts are fluid filled so stick with original ...
- Feb 2018
- 65
September 4th, 2018 02:29 PM #38
September 6th, 2018 10:04 AM #39
Therein lies the problem ... On idle, it vibrates ... Normally it's the mounts ... From experience it's more than 3 mounts ... Engine + Transmission mounts ...
Check if original mounts were installed ... If replacement, then that's the culprit ...
- Mar 2013
- 1
September 9th, 2018 08:29 AM #40Im also having the same exact problem with my 3rd Gen CRV. On idle, my rpm is at 500 only(with or without AC). Engine also vibrates strongly everytime the AC Compressor kicks in but the vibration will disappear when the temperature of the engine reaches half of the gauge. Does the vibration on your crv disappear also after a certain period of time?
I never had the chance to have this idle issue checked by a mechanic because i thought it was just normal? But looking at the previous replies, my idle rpm should be at 700, right?
Question:
Are there any bad effects on the engine if i continue to run it at low idle rpm?
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
