Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 62
    Sep 2018
    #41
    Hi Sir Szekan,
    tanong ko lang kung saang shop nyo pinagawa yung Bushing ng EPS Rack N Pinion nyo?
    issue din kasi ng FD ko yan palit na lahat ng pang ilalim pero kalampag pa din. yun pala yung pinaka Bushing ng Rack N Pinion problema. wala ako makita gumagawa. hassle tong EPS
    Salamat sir!
    Sep 2018
    #42
    Quote Originally Posted by szekan View Post
    hi guys, 1 week is gone and i am still repairing my car. at the start of this thread, my car had 3 problems...
    1) knocking noise from under the car
    2) transmission jerk and delay shifting
    3) low idle rpm
    so far work conducted
    1) changed the following parts
    LH engine mount
    RH engine mount
    Rear transmission mount
    2 x KYB front shocker
    1 x strut mount bearing
    2 x stabilizer link
    plus labor
    31,000 peso
    rebushing of rack and pinion
    rack end and tie rod repair
    ball joint press
    labor
    6,500 peso
    All knocking noise solved.
    2) changed the following
    Surplus transmission and changed the damaged gears
    8 litre transmission ATF
    labor plus home service
    30,000 peso
    Transmission solved
    3) did the following
    new spark plugs
    cleaned throttle body
    cleaned MAF sensor
    reset ECU
    Reset throttle position
    still the car idle is very low.... it is now in the hands of a very qualified technician by the name of Frank De Leon. hopefully he will solve this in his own fashion.... shall update soon
    How often does this happen with 3rd gen crv? Or isolated issue lang ito due to wear and tear?
    Nov 2018
    #43
    Quote Originally Posted by Bloodz View Post
    Hi Sir Szekan,
    Salamat sir!
    Same here po need ko po repair ng eps ng 2009 honda crv gen 3 ko po. You had it done for 6.5k? That's great. May i know also po knino po kayo nagpagawa? Thank you.
    Nov 2018
    #44
    Quote Originally Posted by Paengers View Post
    Sorry i did not read your whole thread. Found what i was asking for. Thank you. Found it in you 3 thread.
    Nov 2018
    #45
    2007 crv 4x2. Bigla na lang umilaw ang airbag light. Ayaw na mag function ang speed lock, seat belt reminder light at chime.
    Sa mga naka encounter na ng ganito sa crv. Saan ninyo pinagawa?
    Mar 2015
    #46
    Quote Originally Posted by dyigon View Post
    SRS Module Php 32k sa Honda Rizal, Ortigas Cainta. baka tumaas na ngayun. nagpalit ako 2016.
    #47
    If it's the seat weight sensor that detects being sat/occupied, the hobo route would be to bypass w/ SRS fooling resistors.
    Sample:
    HONDA 2.7 OHMS OHM SRS AIRBAG RESISTORS RESISTOR .25W 2 AMP FUSED FAULT LIGHT | eBay
    Nov 2018
    #48
    Pwede ba i-repair ang airbag module?
    #49
    I wouldn't trust a repaired module.
    Mar 2004
    #50
    Search FB for specialists who repair computer modules ...
    Nov 2018
    #51
    Yes on Facebook messanger search for
    Gasper pilapil Jr. And tell him a friend whom he repaired the rack and pinion black crv recommended you. He charged me 5k. However usually with the Rack and pinion, the outer tie rod and rack end also needs replacement or repairs.. So keep a seperate budget for that.
    Sir any feedback sa repair done with your crv EPS by gaspar pilapil jr? Thank you
    Nov 2018
    #52
    Decided to try gaspar pilapil's services. repair of EPS alone will cost you 5k. Had my tie rods and rack ends repaired also, 850 each, total or 4 heads = 3.4k. Replaced the stabilizer links as well, (replacement)2.4k pair. All work done for 10.8k. So far so good.
    Nov 2018
    #53
    After a week, may noise s left side ng suspension. I suspected it to be the balljoint. Went back to gaspar to have it checked. True enough it was the balljoint. Had it repaired. 900*. Left and right side. Nice quiet ride again!
    Jan 2019
    #54
    The mechanic said there are only 3 mounts which needs to be changed. There is no noise or any sort of cluck when driving on rough roads. It's super quiet. But on idle with air con, there is vibration. And also sometimes on reverse gear
    Sir Szekan, naayos na po ba ung vibration issue nyo?
    Mar 2015
    #55
    3) low idle rpm
    LH engine mount
    RH engine mount
    2 x stabilizer link
    plus labor
    31,000 peso
    ball joint press
    labor
    6,500 peso
    30,000 peso
    Transmission solved
    new spark plugs
    cleaned MAF sensor
    reset ECU
    hi where did you bring your crv for transmission repair? can you give me the contact no., problem also with jerking i think its my transmission is already in bad shape.
    Thanks
    Mar 2015
    #56
    Quote Originally Posted by joepaps52 View Post
    hi where did you bring your crv for transmission repair? can you give me the contact no., problem also with jerking i think my transmission is already in bad shape.
    Thanks
    no jerking now after replacing output shaft speed sensor. hoping its solve the jerking.
    Nov 2018
    #57
    Good to hear that sir. Where did you get the spare part and had it repaired? Thank you
    Paano umabot nasira ng ganyan transmission ninyo?
    Mar 2015
    #59
    bought the speed sensor from Honda Tandang Sora. replace it myself.
    Mar 2015
    #60
    akala ko rin transmission na problem but after check with my OBD, fault code lumabas is P0723-02 which is Output Shaft Speed Sensor.
Honda crv 3rd gen issues please help
