Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 62
    #21
    Quote Originally Posted by szekan View Post
    Not sure about the dedicated OBD. But they used theirs and tried to reset many things but nothing happened. There is no stored error codes or engine check.
    well i reset my crv using the obd with honda software, by the way where did you bring your crv for rack and pinion repair, i also have problem with my rack and pinion, maybe this is common problem with 3rd gen.
    Feb 2018
    #22
    Quote Originally Posted by joepaps View Post
    Yes on Facebook messanger search for
    Gasper pilapil Jr. And tell him a friend whom he repaired the rack and pinion black crv recommended you. He charged me 5k. However usually with the Rack and pinion, the outer tie rod and rack end also needs replacement or repairs.. So keep a seperate budget for that.
    #23
    ok thanks.
    Feb 2018
    #24
    OK so the news is that my car has been completely checked but there is nothing wrong. Yet the idle seems to rough for me specially when the air con comes alive. I would say it's like as if I am sitting in a diesel engine car. When the air con is not working, it seems fine. As soon as the air con comes alive, my car vibrates alot.
    Mar 2004
    #25
    Have your aircon compressor checked ... Might need additional lubricant ... But it still should not vibrate that much ... If car, if vibrating at idle it's usually the engine and transmission mounts ...
    Mar 2015
    #26
    so whats the idle rpm before the aircon clutch engage and the idle rpm after the aircon clutch engage.
    #27
    Quote Originally Posted by joepaps52 View Post
    if your owner's manual is with you, it should be there, po.
    if you don't have it...
    hintayin po natin ang responses.
    Jan 2016
    #28
    Agree, check your mounts
    Sep 2016
    #29
    sir possible cause ay kulang sa power. try to check air filter element, maf sensor, spark plugs, ignition coil, fuel filter at clean the throttle body. add yung sinabi nilang mga mounts. good luck sir :-)
    Mar 2015
    #30
    no not for my crv, baka need talaga nya reset the throttle position to default para di mahirapan engine nya pag engage ng aircon.
Honda crv 3rd gen issues please help
