Results 11 to 20 of 62
- Feb 2018
- 65
August 22nd, 2018 06:17 PM #111) My crv is 2. 0 and this variant comes with Eps po.
So the latest news is I rebushed the rack and pinion and now the knocking noise on rough road is gone. First shop gave a price of 15k then second shop 13k then third 9500 and then finally one guy did it for 5k.
2) I changed the spark plugs and checked the throttle body, it's super clean. Next I put the car on OBD scanner and there are no codes at all. Yet the car idles at 400-500rpm. Car doesn't stop or anything, just some annoying vibrations on idle....
3) I found a shop in banawe who is willing to repair my auto tranny for 30k... Not sure if this is a good deal?
I was thinking to try to flush the ATF but all the mechanics saying that this sort of jerk is related to clutch problem not Atf....
August 23rd, 2018 12:10 PM #12
Did you have throttle body and idle control valve cleaned before? ... Did the mechanic perform idle relearning? ... Check online on how to perform idle relearning ...
- Feb 2018
- 65
August 23rd, 2018 01:00 PM #13
August 23rd, 2018 02:17 PM #14
- Feb 2018
- 65
August 27th, 2018 04:25 PM #16hi guys, 1 week is gone and i am still repairing my car. at the start of this thread, my car had 3 problems...
1) knocking noise from under the car
2) transmission jerk and delay shifting
3) low idle rpm
so far work conducted
1) changed the following parts
LH engine mount
RH engine mount
Rear transmission mount
2 x KYB front shocker
1 x strut mount bearing
2 x stabilizer link
plus labor
31,000 peso
rebushing of rack and pinion
rack end and tie rod repair
ball joint press
labor
6,500 peso
All knocking noise solved.
2) changed the following
Surplus transmission and changed the damaged gears
8 litre transmission ATF
labor plus home service
30,000 peso
Transmission solved
3) did the following
new spark plugs
cleaned throttle body
cleaned MAF sensor
reset ECU
Reset throttle position
still the car idle is very low.... it is now in the hands of a very qualified technician by the name of Frank De Leon. hopefully he will solve this in his own fashion.... shall update soon
- Oct 2012
- 4,851
August 27th, 2018 05:28 PM #17
- Feb 2018
- 65
August 27th, 2018 05:59 PM #18Yes not yhe Iac value... Maybe that's the problem I am not sure... This crv doesn't have any physical adjustment to control idle...
Hopefully by tonight I shall know what is the real problem.... Technician also said that these problems which I am facing are very common for crv....
- Jul 2009
- 3
August 27th, 2018 06:49 PM #19
- Feb 2018
- 65
August 27th, 2018 08:38 PM #20
if all we are interested in are fuel versus electricity expenses, someone must already have made...
electric powered cars
