Good day to all. Planning to buy my first honda, and pasok sa budget civic FD. May differences po ba yung 1.8s ng years 06 07 and 08? If yes, anu anu po? And compared sa 1.8V, may ibang differences po ba aside sa mags and stock fog lamps?
^ octagon-ish na din ata ang mga headlights and tail lights ng mga 2009 up
Btw, iyong mga naka abs na na models equipped na din ba ng vsa?
when you look into the abyss, the abyss looks into you
Currently looking into the MT FD. Magkano ang tamang presyohan ng 2.0S-L ngayon? Tia
Browse OLX to get an idea of the range (420-500K depending on the seller. Some sellers can go as high as 700K because if mods) Factor in other things such as mileage, condition of the tires, brakes, suspension system, interiors, any modifications done etc. The 2.0S-L is also quite fuel-thirsty but very fun to drive on highways. Expect 6.6-7.5 kpl city, 9-10 kpl highway. If you drive it conservatively you might get better numbers but what's the point? Just get the 1.8S if you're after fuel economy.
^ i agree that those are basically the common ailments nga of the fd. Replacement spare parts for them are not hard to find nanaman
But if you're going to get the 2.0 variant, you're going to be spared of the rack & pinion problem since the 2.0 is already electric power steering (eps) equipped
Apparently the 2.0 variant doesn't have the engine support problem that the 1.8 variants have. Not sure about the hub bearings but so far no problems with my 2.0S.
Thanks for the response. Based on my initial canvassing, ang hirap pala maka hanap ng 2.0S-L. its either sobrang mahal na (exteremely modified) or sobrang taas ng mileage (like 130K+). And sobrang konti din karamihan 2.0 AT
One of my 2007 FD foglight went bad, any idea where I can buy an original or replacement? How much too? Where to have it install?
Thanks in advance!
It's very likely that only the bulb has gone bad. Mura lang naman replacement nun. If for some reason, you want or need a new set, get a DEPO branded set since they are made of glass, are well-sealed and comes with plug and play (no splicing) wiring harness. My set still looked shiny and new until the day I sold the car. It was 10 years old.
Normal lang ba kumukurap headlight ng 2011 fd? Vti-l australian version i think this is just the same 2011 S version jan satin. Hindi naman battery kasi minsan kumukurap kahit na nakarekta ako.
Aside from sa casa, where can I get parts to change my pre-mmc fd to mmc fd? Car is 2.0SL model.
Yun nga din suspetsa ko sir kaso sinilip ko makina maayos naman lahat walang mga loose connection. Hindi rin naman sya humihina pag nagdagdag ka ng load like nagbukas ng ibang ilaw o ano pero may time talaga na kumukurap pansin na pansin lalo sa gabi. May nabasa akong forum sa sa ibang site na may ganitong sakit daw ewan ko kung isolated case lang. Pano ba checkin ground ng ilaw?
