Results 51 to 60 of 60
- Apr 2016
- 203
January 21st, 2018 11:51 PM #51Well.. the problem was I didn't ask enough questions. I mean.. I just entered the shop and told them to replace the steering system pressure hose as Honda told me the diameter was so small and I told them to replace the black steering fluid. I nearly left the car there but just stayed to watch. After replacing the pressure hose.. he was not sure how to flush the black fluid...
What he did was remove the pressure hose pressure switch sensor valve partially and let the steering fluid drain a bit while filing up the reservoir.. but after doing it for 2 minutes and closing the valve.. we can no longer turn the steering wheel with engine on. He thought sira na pump. Buti bumalik steering but with huge noise after 20 minutes. I didn't know what happened.. but after analyzing for days the mechanics of a rack and pinion.. kanina I realized what if he pumped so much air the rack and pinion no longer works because it's compressing air instead of hydraulic fluid?! Is this possible. i'm still analyzing what happened...
But i'll focus on the brake master first bukas. I'll buy a black paint and sandpaper and have the new service center sand paper the flaked off paint of the brake booster caused by the corrosive leaking brake fluid before doing the bench bleed and reconnection to the steering system.. someone suggested this early here.. tama to sandpaper it right.. hindi papasok debris sa loob ng booster?
After the brake master is successfully installed and bleed. I'll leave the car at Honda to flush the black steering fluid costing 3k (with chemical daw).. then continue analyzing what happened last week when the steering wheel stopped turning after he drained the pressure hose partially.. dapat sa return line mag drain. He also risked damaging my pump.
Maybe he is not really the head mechanic but just an apprentice whom I thought is the head mechanic.. just not to put the company at bad light.. they have few customer and kawawa naman to give them bad advertisement but need to share what they did for education and learning.
- 54,205
January 22nd, 2018 09:12 AM #52but you already uploaded the picture of the shop, complete with address, along with your critique.
you already put them in a bad light.
January 22nd, 2018 10:14 AM #53
Isa pang paraan para magpalit ng brake fluid/power steering fluid eh “syringe” method. Higupin ung fluid hanggang sa maubos, tapos top-up lang ng bago. Syempre may bleeding pa din yan.
- Jul 2013
- 2,450
January 22nd, 2018 10:15 AM #54brake still not fixed hahaha
my two cents. enroll in TESDA and fix your vehicle DIY.
- Apr 2016
- 203
January 22nd, 2018 10:37 AM #55I called up PowerTor. Talked to the technician and discussed with him how he would do it. So far, ok naman kasi they are willing to spend 2 hours to bleed using hose and bottles whereas in Car Zone in banawe.. they don't have time to use hose because sobra daw haba pila ng mga cars pagawa dun so hindi ma focus on detailed bleeding.
When I passed by Honda to buy brake fluid on way to PowerTor. Kinausap ko yun service adviser asking him on the minute details of the process. So far marunong naman mag bleed. And considering meron about 100 mechanico sa Honda.. then pinagawa ko na lang replacement sa Honda casa with 3,000 pesos surcharge for parts bought outside. Malayo rin PowerTor and my brakes may not last that long. At least I can complain to Honda management if hindi marunong mag bleed and make sure tama yun pedal play (which dr. d emphasized pero hindi ako familiar if not normal ang pedal play)
About yun service center who doesn't know how to flush steering fluid and doesn't focus on bleeding.. remember the mechanico there introduced air to my steering system by opening the drain at the pressure hose side and partially pa.. at least hindi nasira yun pump or rack and pinion.. kasi air in steering fluid can damage the pump. Since mukhang ok naman yun pump.. then I can forgive them for their mistake. I already removed the pictures of their shop at imageshack.. the photos in this thread will disappear in a while too.. if not.. then let's request the mods to just delete it (only me and dr. d posted the pics (when he replied)). It is only for reference for those immediately people here at present for our discussion and not for future reference for hundreds and thousands who are not present with us now. It is because of them that I realized some mechanico doesn't focus on hydraulics physics or principles (which is what the steering system and brake system rely on pa).
Thanks for all who help as it gives me the knowledge and make me understand the process a bit more giving me the information I needed to decide where to have it replaced with peace of mind for years to come...
- Jul 2014
- 7
February 1st, 2018 11:22 AM #56
- Apr 2016
- 203
February 1st, 2018 11:42 AM #57Pinagawa ko na sa casa last January 22 kasi the others don't do proper bleeding procedure.. at least sa casa puwede complain if meron pa air... here is my new one:
problem is the paint sa brake booster.. Honda said they don't fix it.. could I just remove the black one and paint black paint over it? is the metal iron or aluminum sa brake booster so I can estimate how fast it can deteriorate if left alone.. tnx..
- 54,205
February 1st, 2018 11:48 AM #58the paint job is better done, prior to replacement of brake master. the metal is not paint-sensitive. most of them are iron.
i just clean the booster surface, sandpaper it, brush on rust converter if i have any, then paint it with my choice of color. and as i have no artistic objective, i just use red lead paint.
the booster can last years, before rust eats thru the metal. but once it does, you will rue the day you decided not to fix it earlier.Last edited by dr. d; February 1st, 2018 at 11:51 AM.
- Apr 2016
- 203
February 1st, 2018 11:53 AM #59
- Jan 2018
- 7
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
