Results 1 to 10 of 80
- Jul 2014
- 13
August 11th, 2014 02:28 AM #1Feel free to ask any concerns about your ford cars. I'll help you. Or better yet, i can fix it for you.
August 11th, 2014 06:46 AM #2
Nice. Is it advisable to buy a second hand focus tdci manual or power shift?
The latter has so many problems and expensive to repair?
Also is the manual focus tdci clutch lining different than standard linings? I read somewhere its about 80k to replace the clutch release bearing and pressure plate?
Thanks
Posted via Tsikot Mobile App
- Jul 2014
- 13
August 11th, 2014 11:37 PM #3Sir for me, the manual type is more advisable. Marami po kasi problems ang automatic. And true po na expensive po ang parts ng manual focus tdci pero hindi po siya sirain. If theres proper maintenance, matagal po bago masira or mag wear out. And mas marap dalin ang manual transmission. Its up to 6th gear. Maririnig niyo pa ang turbo everytime na switch gear. Honestly, the diesel type of focus encountered so many problems that ford cant perfect. Kaya nga po wala ng nilabas ulit na diesel. Pero for me, if i have the money, bibili rin ako ng focus tdci, matulin po. Hehe!
- Apr 2008
- 210
August 12th, 2014 12:20 AM #4Sir ano ba ang ginagamit na atf sa ford escape 2009 model?
August 12th, 2014 03:22 PM #5
Salamat luigi, as follow up. Madami pa problema ang focus tdci aside from transmission?
Ano po pa?
Also parang gusto ko ng expedition na 02 tapos convert sa diesel. May gumagawa sa muntinlupa using surplus engine u like hehe. Any comments on this? Sirain din ba expedition?
- Jul 2014
- 13
- Jul 2014
- 13
August 25th, 2014 04:34 AM #7
- Jul 2003
- 573
August 25th, 2014 04:54 AM #8Sir Luigi, my focus 2009 AT got Transmission fail and will not start, starter won't run. Shifter Lock when depressed, panel displays 'R' even when not moving the shift lever. what could be the problem. Just drove it for about 50km and when I placed it in reverse, cannot put it back to drive.
- Aug 2014
- 1
August 25th, 2014 11:37 AM #9Hi! I own a Ford Escape that was converted to LPG. The engine would start but would shutdown after a few seconds. Unfortunately, I can't locate the company where I had it converted anymore and their shop in E. Rodriguez has closed. Can you help me find out where I can have my vehicle fixed? Thank you.
August 25th, 2014 12:47 PM #10
^ you may try contact xoom auto gaz. they might be able to help you
https://www.facebook.com/xoomautogaz...hoto&sk=photos
Very informative discussion guys. Thanks a lot!
Liquid tire sealant
