good day! 2012 ford everest 4x2 limited edition reverse problem. kapag inclined ang terrain, ayaw mag-reverse ni eve. pero kapag flat terrain, ok naman ang reverse niya. ano kaya problema?
thanks in advance..
thanks in advance..
this is a pain if the mechanic is not trained..
Ford Harmonic Balancer Replacement Tools and Tips How-to - YouTube
Mga Paps.. Baka may alam kayo na Mechanic Shops and Accessories sa Cagayan Valley. Tuguegarao City po to be exact. Hanap kasi ako installer ng DashCam sa Eve Trend 2017.. Baka lang po may alam po kayo.. Salamat po ng madami..
Twoo weeks ago after the 30k pms of my ford ecosports titanuim I noticed sounds coming under the.vehicle near the front whenever I press the brake pedal during stop and go driving. I dont hear the sound when im driving 40 to 50kms/hr when i step on the brakes. What be the possible issue/s?
Sent from my ASUS_T00J using Tsikot Forums mobile app
something loose lng siguro...
I hope so sir. Tnx much
only downside sa casa is slightly more expensive like their air filter.
seems like you skipped the every 6mo maintenance interval. meron naman reminder...
If tech is telling the truth, then yes you need to purchase a new BCM. You're HID may not be canbus safe, and that fried your BCM. There is a reset counter in the BCM module, once it exceeds x amount of trip/reset value, it will shutdown for good.
If He's playing with you or just lazy, he can just reset the bcm module and drive away like nothing happened. But then, you need yo go buy a BCM friendly HID or disable the error checking of BCM for low beams.
Ooohhh...so how can we know if the retrofit or HID upvrade is BCM friendly? Buti na lang am planning soon to upgrade mine. Thanks Janemar for that..
