Regarding sir sa Ford vehicles. First time owner po ako ng 2nd hand ford everest 2014 model m/t. Saan ho ba maganda magpa service and PMS? Saan ho ba mura ford spare parts? Ano recommended engine oil na gamitin? Saan recommended magpa service outside CASA? Ano ba dapat ko echeck sa everest for now? Kakakuha ko lang this morning. Thanks
Regarding sa murang parts... Banawe is the place to look.
Sa recommended oil, please refer to the owners manual andun nakalagay yun.
On what items to check... Find out about the service history of your vehicle na pinagawa ng previous owner.
If you happen to have the service manual from Casa mas maganda at least meron ka pwede i compare sa service checklist na nasa manual din.
Sir thank you for the reply. Problem is the vehicle i bought wala ng bookletmat,di komkakilala. Bought it from a dealer of second hand cars. Im using it now for the second day somfarmwala namang problema na major. Hirap lang ako sa clutch nya compared to my revo diesel and honda jazz. For a one year old car w 40 thousand mileage should i drain all the oil/ liquid? Transmission differential oil? Brake power steering fluids and engine oil? Drain rzdiator and replace the coolant?
Hi luigi can you text me your number09175168800 09228166868. Wheres your location. Id like to have my everest checked.
I'm not sure whether it's turbo or the actual engine itself, basta nag lowpower and tumirik nalng ako and I heard clanking sound sa gilid ng engine gawing right side if you're infront of the hood, di ko alam kung anong nangyari o kung saan nagumpisa. tapos di na nagstart, nagtry ang mechanic na kakilala ko na paikutin ang pulley pero ayaw umikot mukhang nagstuck up na daw ang makina. Masakit sa ulo actually, parang nagsisi na ako na kumuha pa ako ng Ranger imagine what if during your 3rd year saka lumabas ang problema kung kelan wala ka ng warranty, or on your 100k reading? ang sabi ng Casa engine is around 400k, sa mechanic naman it would cost 100-150k to fix the engine kung sakaling nagkadamage dahil sa turbo issue.
if this is a batch defect or design flaw dapat siguro ngayon palang i-acknowledge na to ng Ford and start recalling our Ranger to fix the issue, actually madami narin akong narinig regarding dito, even ung technical head nung nalaman nya nagyari sa ranger ko halos alam na nya symptoms sya pa ang nagsabi sakin mismo, problem lang ung warranty ko may issue.
sir tholitz pwedeng malaman kung anong model ng ranger mo? my ranger is 2014 XLT manual transmission...
nag aalala din kasi ako baka mangyari sa akin yan... i was planning to blank the EGR pero di daw pwede tong T6 kasi un inlet plastic at baka matunaw..di ko alam kung totoo un...pero kung di mabablank prone naman sa dumi ang turbo ...planning to install a catch can as well...looking for help kung sino pwede gumawa nito...
Sa wakas, ok na 2005 Ford Focus ko! Coil on spark on cylinders 1 & 3 ang problem.
I was able to successfully source out the Parts need for my Ford Ranger now complete na lahat from oil pump to Turbo Charger.
Sir luigi my 2002 ford expedition is experiencing hesitation when going uphill minsan even on flat roads. Aircon will shutoff. Pag pinatay engine and restart back to normal uli. everytime maghesitate engine I just restart. Any idea what is the problem? Thanks!
Guys. My new fiesta got hit. Tangal yung mini door a gas socket at butas din yung bumper, dilapidated na din dun a lower left side.
question is... if gagawin ng Ford to... do you have any idea kung gaano it katagal? aabutin ba ng one (1) month ito or mga days lng?
The SA at ford can give you the estimate. Of course you have the police report and the LOA from the insurance company to deal with first. If parts are available it could be a month. If not, then be ready to wait.
If the hole is prefectly squarish,it could be the provision for the tow hitch
hi mga sirs ask ko lang. i own a second hand ford everest m/t w 45k milesge. yesterday while starting ky everest for wsrm up before using it. di na nawala ABS light ko. used it the whole day di na sya nawala. what could be the problem? imnplanning to bring it to a ford dealership. any dealership in manila na madali kausap? thanks for your replies
