back to hot ac, i tried it kanina i just left it alone. at first it was blowing warm air then after 5 minutes it blew cold air. could this blowing of warm air be normal then? maybe getting rid of condensate from the evaporator first or warming up the air in the cabin before cooling so there will be no misting on the glass surfaces?
There was a topic about the airconditioning system of the Ford Everest and some other models taking a while to "start up" or initialize to prolong system life ...
Ako din, sa umaga, heater mode sya. Ang ginagawa ko lang, i lower the settings by 2 degrees vs sa ambient temp (as indicated sa MID).
By the way, yung headlights ko, replaced a month ago (both LH and RH), so far ok pa naman. Replaced nila yung pair kasi baka bumigay sin daw yung LH na headlight (ang nasira na leveling sa akin ay yung RH). Hope ok na, kasi sabi ng tech, new part number na daw, improved (di ko naman nakita yung P/N).
Mga Katsikot, ask ko lang kung saan makakabili ng rubberize floor mat sa Eve natin. Nabasa ko na dati dito sa forum pero di ko na makita.
Just got my unit last Jan. 4 White Trend model 2017. As far as I knew, lahat kami nakangiti pag pinaguusapan namin si Eve. Oks na oks and sulit na sulit ang features compare sa kalaban. Panalo ika nga, salamat sa mga katsikot natin lalo na sa mga nagbigay ng owners unbiased review sa unit nila. After 1K na natakbo, I got 16.3km/l sa trip computer with a speed of 70-80KPH. Baka pa daw tataas ang FC lalo na if gagamitin yung cruise control nya.
Mga bossing baka may feedback tayo jan sa floor mat kc di rubberize yung floormat na kasama. TIA po.
Cruise control baka mas matakaw kc meron sya kailangan i maintain na speed at rpm (minimal diff), with regards sa matting, try mo deepdish or shark
Sent from my ASUS_T00J using Tapatalk
Deep Dish Mats 6500
Accessories for the new Ford Everest - Lamson Digital Electronics | Facebook
09954282205
Sent from my SM-A9000 using Tsikot Forums mobile app
Anyone nag pa 20K kms P.M na dito? (2nd 6th month period) how much?
not true. i get better mileage using my foot than the eve's adaptive cruise control since i can see from a distance what the ecu can not see with its radar. malayo pa lang i can let go off the gas pedal and slow down without stepping on the brake. the adaptive cruise control waits until the last 30 meters then brakes, wasting energy in the process.
example: at 110 kph i can only get a best of 10.1 km/l with adaptive cruise control at sctex-tplex (good luck using cruise control at nlex!) but with manual control my mileage is up to 11 km/l.
same question, mine is due also.
i got a quote from ford greenhills/makati/cainta for 14,500. same scope of work as the 10k km pm - change oil, oil filter, air filter (3.5k!), brake cleaner and brake anti-squeel (1.9k for the little bottle). i'm waiting for ford commonwealth to respond to my email. in case same din i'll ask then to exclude that brake cleaning and anti-squeel, hindi naman kasama sa warranty ang brake pads and discs.
I will try to compare the FC sa Cruise control vs manual. Baka nga mas matipid pa rin ang manual acceleration natin. Minsan kc mejo mas mabigat apak ko sa gas, wherein sa cruise mode eh consistent ang acceleration nya. Mas maganda yata yung deep dish natin bossing. How about dun sa cargo tray natin, pagkakaalam ko ibang price nun.. Salamat.
Grabe taas (kung same procedure sa 10K)
20k maintenance for (addl) check up:
1. May amoy sa aircon pag on mo (something like lpg or what, amoy bago sasakyan), after few seconds mawawala na
2. Vent actuator motor behind the glove box (keep on openning/clossing) and 3rd row foot aircon (blows hot air)
3. Clean drainage of panoramic roof to prevent leaks..
So far.. everything is good..
Yung deep dish mats ba tinatrap ang dirt like sa 3M Nomad? Based kasi sa pics parang hindi
Sent from my LG-D855 using Tapatalk
