I replaced my rear plate lights due to socket burn issues highlighted by members of FECP. Bought Osram T10 W5W LED lights from Lazada as replacements.
original bulb, note burn marks on the socket
replacement LED bulb
new bulbs in the box
Procedure on lamp replacement including bulb specs chart can be found on pp. 240-242 of the user manual
damn akala ko isolated....
mas mababa ba yung wattage nung replacement kesa original bulb?
Sent from my SM-G950F using Tsikot Forums mobile app
ok bro will take note of this thanks for sharing. looks like hindi kaya ng socket yung init ng original bulb.
[emoji108] Could you also share the link to the bulbs?
Osram T1 / W5W Universal Park light Peanut Bulb 12V 6 K (White) | Lazada PH
Sent from my GT-I9505 using Tapatalk
Much appreciated
ano pwede ipalit sa high beam bulb na mas malakas pero bulb lang palitan?
There's the Night Breaker Laser as well na supposedly brighter and whiter but with shorter life expectancy. Not sure about its availability though.
An suitable alternative to the NB Unlimited is the Philips Xtreme Vision +130.
Hi Tsikoteers, I have a question to those who already upgraded their sound system but retained SYNC 2 or 3.
Was the noise cancellation system affected when you changed speakers or added an amp?
Will it affect warranty? not sure if wires were spliced. Might be plug and play kasi
Was the sound quality miles apart from OEM? Stupid question but I just need to ask. hehe
Estimate cost of the upgrade? Cost range will do. Assuming change of speakers (10 for Titanium), add amp, add dsp, deadeners, wirings.
Thanks in advance
It would depend on your appetite for upgraditis. Most basic upgrade wiukd just be replacing the front speakers. But this would depend on your speakers. Puedeng less than 5k to skies the limit, if you get those high end focals and bewiths... but for the speaker replacement, dapat no impact on warranty.
The moment you add an amp may impact na yan sa warranty as you will be affecting the electricals.
Best decide first how much is your budget. To illustrate..
My wishlist would be a helix dsp plus 4 channel helix amp to drive focal 165f (full active) seps. Then a 10 inch sub powered by a mono amp.
Approx 20k for the seps 27k for the dsp and another 17k for the 4 chnl amp. Not yet decided on which sub and amp combo.
For sound deadening, i would be allocating around 8k.
any one installed headrest monitors for the 2nd row seats?
Sent from my RNE-L22 using Tapatalk
