Page 330 of 389 FirstFirst ... 230280320326327328329330331332333334340380 ... LastLast
Results 6,581 to 6,600 of 7777
    Oct 2003
    #6581
    Wala ba talaga way para automatic fold mirrors pag engage ng alarm ng everest?
    Feb 2017
    #6582
    nasa lock position na? 5 position yan.. dapat mag release sa lock position..
    Okay na mga brother. What I did was start the engine P-R-N-D-P. Then natanggal. Hassle di ko nagamit buong araw. Salamat mga bro!
    Feb 2007
    #6583
    Anyone using any oil additives like Ceratec on their eve?
    Sent from my SM-G950F using Tsikot Forums mobile app
    Apr 2009
    #6584
    Quote Originally Posted by fleas2016 View Post
    I won't recommend using it and the user manual doesn't recommend it either. A waste of money imo.
    Sent from my GT-I9505 using Tapatalk
    Mar 2004
    #6585
    Anyone using any oil additives like Ceratec on their eve?[/URL]
    There's risk of damaging your engine ...
    #6586
    urgent message misis ko kanina (sa work ako) nalaslas yung gulong sa likod thanks sa bakal na iniwan ng mga naghuhukay sa visayas avenue. mahaba ang hiwa di na pwede vulcanize. sayang ang kapal pa naman nung gulong.
    2nd time na madamage yung tire na yun. malambot ang nitto! yung tires nga sa harap 30% worn na wla pang 2 years.
    misis bought accelera, baka mas maganda pa. 8k ang isa. achilles sana kaso walang 275/55r20. anyway pag maganda performance will buy 3 more later para pantay, benta ko na lang yung 3 nitto.
    Feb 2007
    #6587
    Thanks to those who gave their input re: additives. I'll hold off muna. I've been using them in my older diesel ride and have been very satisfied. Post warranty na lang siguro.
    Sorry to hear that yebo. Hassle. Curious if the TPMS indicate there was problem though?
    #6588
    may indication nga, yellow/amber light na korteng U na gulong saka nag-message na low tire pressure. nawala na yung message pero meron pa din yung U. di alam ni misis i-reset so it will be there until i get home after xmas
    8.5k pala yung accelera at na 275/55r20. kind of nagulo pa yung plan ko na palitan ng 18s. buti na lang medyo mura lang. balak ko kasi palitan ng 275/65r18 pag pudpod na yung 20s na nitto.
    Sep 2017
    #6589
    mag Sirs, ilalabas ko sa casa mamaya new Everest Titanium+. Any tips on mods/car care?
    I'm thinking lower chin (front and back), ceramic coating, though dont know where pa.
    Looking forward to suggestions on reliable shops also
    Feb 2011
    #6590
    Ayy, bakit ka lipat sa 18? Ride comfort related?
    go for a shock upgrade? ridemax 4way adjustable seems reasonably priced
    #6592
    Quote Originally Posted by pobre24 View Post
    yes. function over form. matagtag kasi pag papunta ng farm.
    #6593
    just now, wifey went to cherry for groceries. guard insisted to open the tail gate for inspection, sees it opened by the power lift gate, then he slams it shut! wifey checks it again, lift gate won't open. wifey berates the guard, calls the guard oic and cherry supermarket manager. after many furtive minutes they use the key itself to unlock, door opens. i told wifey to open and close remotely and by the use of the tail gate button on the handle and to listen for any abnormal sound. fortunately no gears broken.
    wife has incident recorded. berates guard oic for putting on duty an untrained guard. tells the same to cherry supermarket manager. tells them power lift gate costs 50k (how much ba talaga?). nanginginig daw sa takot yung guard nung narinig ang presyo e. guess he will not be opening any lift gates anymore after this.
    Jan 2017
    #6594
    Just don't open the tailgate. Ako binubuksan ko na lang ilaw para makita niya na wala namang laman, nothing to inspect.
    Pag naginsist ang guard, sinasabi ko "Ayoko nga, baka magtanim ka pa ng shabu dyan." Pinapapasok din naman ako
    Nov 2017
    #6595
    Quote Originally Posted by boinkssayo View Post
    +100 sir right naman natin not to open tailgate natin pero private area yung mga mall they will insist na if you dont follow our rulea so not enter[emoji31]
    #6596
    Just had my 1st PMS today; Mileage = 2,500 6 months na.
    Brake cleaner 228.0
    Elem Asycarb A/CLNR 2,901.92
    Helix Ultra AF 5W30 (9) 4,515.00
    Filter 617.79
    Battery Test 224.0
    Misc 504.0
    Total ~8,989
    Ford Calamba
    Madali lang ba remove yung air intake filter so I can still use yung old one kasi 2,500 palang naman natakbo ko?
    As per others advise here, After my 12th month PMS, I plan to bail out because madaya itong ginagawa ng Ford forcing you to PMS kahit ang layo pa naman sa interval mileage. Sa Montero namin at Lancer, Mitsubishi just follows the mileage, walang issue sa kanila sa warranty pa din basta within 3 years.
    When I called up Ford, I was surprised to get a schedule the following day kasi, maluwag casa. walang ginagawang job.
    TIA.
    konting latch lng yan. mark the air filter so when they replace it, you know its your old air filter. ask them to clean it for you and put sa tray sa likod.
    Mar 2004
    #6598
    Quote Originally Posted by maxpedition View Post
    Most likely they will let you in unless there is an emergency alert situation ... they would not want to hold up the line of cars entering the car park ...
    Aug 2017
    #6599
    Ford everest trend owner here. Wife insisted on installing dark tint for privacy, specially if shes the one driving. The problem is its too dark specially during night driving. Changing the tint is not an option (because wife said so), so i’m planning to just change the headlight. Any suggestions on LED headlight replacement? And will it void the warranty? My eve is only 2 months old. Thanks guys
    Jun 2009
    #6600
    Quote Originally Posted by Logan15 View Post
    Para sa akin go for VCool tint, no need to replace the headlight.
Ford Everest 2015
