Page 232 of 389 FirstFirst ... 132182222228229230231232233234235236242282332 ... LastLast
Results 4,621 to 4,640 of 7777
    Apr 2016
    #4621
    Quote Originally Posted by argarinchoy View Post
    Hello Guys,
    sa mga nagpa palit na ng headlight unit, same part number po ba ang ipinapalit? sa kasawiang palad...bumigay na rin ang auto-levelling (r/h side) ni EverBreast. Unit is just a month old after release...
    RH Headlight motor assy lang pinalitan sakin last 27Nov. Ok naman til now. Madami na daw stock sa planta ng motor assy. Di ko lang sure kung same part number ung ipinalit.
    Tinanggal pa din ung buong headlight kasi naka clamp sa loob.
    May 2011
    #4622
    Hello guys. Sorry kung natanong na to before. Meron TPMS ang eve right? Talaga bang wala sya display for individual tire pressure? And wala ba talaga tayo auto lock feature when the car moves or reached a certain speed?
    Sent from my SM-G925F using Tsikot Forums mobile app
    #4623
    Quote Originally Posted by vin23 View Post
    yung tpms mag alarm lang at may indication anong tire ang deflated.
    may autolock yan at 20 kph. hanapin mo settings sa sync2/3 under vehicle settings.
    May 2011
    #4624
    Thanks!
    Aug 2014
    #4625
    I think my case with my 3.2L Titanium Premium 4wd is the worst so far. I bought it last february at ford sta. rosa but maintained at ford malolos. Last april I had my first incident of limp home mode while travelling at NLEX. Set the adaptive cruise control at 116 kph when suddenly the car infront of me reduced its speed, my eve braked just before I step on the pedal but went on limp mode, various indicator lights went on (pre-collision warning, traction control, check brake) and limits the speed to 30-40 kph no matter how hard you step on the accelerator. I managed to pull over on the side after a nerve racking and near rear collision with a speeding car. (from fast lane to the shoulder) and reached petron marilao while on limp mode. I turned the key off and back on, the indicator lights went off and went back to normal as if nothing happened. I reported the incident and went to the casa to run a diagnostic test but to my dismay..NO FAULT CODE.. Guess what? It happened again yesterday, but new indicator light went on, it says Hill Descent Control Active. I will give you an update tomorrow with the result of the test to be conducted by ford malolos..
    Sent from my SM-G925F using Tsikot Forums mobile app[/QUOTE]
    #4626
    Quote Originally Posted by mang andoy View Post
    [/QUOTE]
    1. ano setting ng precollision? happened to me before nasa high ang setting. now nasa normal na lang di na naulit. pero when it happened just like yours papa limp mode and brakes were hard. that was during a TEST, talagang i tried to collide with a cardboard box experiment ko lang kung mag apply nga yung brakes by its own. i had to put it in neutral to reset.
    yung pag paatras ako nabibigla ko gaya kanina lang 15 minutes ago ayun nag-brake na naman siyang magisa. neutral lang reset na siya.
    so either put in neutral or stop/restart to reset. disable mo na lang lalo na kung mahilig ka mag-tail gate.
    2. yung hill descent control SURE KA HINDI MO NAPINDOT? madali lang mapindot yung mga buttons dun like kung may hinahanap ka dun sa area na yun. baka naman napindot mo sir?
    wala talaga error code yan kasi it is just doing its job.
    Aug 2014
    #4627
    The pre-collision setting is normal. My hand is on the steering so its impossible that I could have activated the hill descent control, and I wasn't tail gaiting. The distance was set to 2 bars. NLEX road begins to narrow approaching the long bridge (bulacan-pampanga boundary) due to road widening so cars would slow and so did my everest. I think ford must do something with the programming of when to activate the limp mode. Nakaiwas nga ako sa collision infront pero muntik naman ako mabangga when I try to pull over.
    #4628
    Not sure kung na post na to dati, but the ranger (and malamang pati everest) passed the "moose test" The new Toyota Hilux 2016 fails moose test - YouTube.
    Aug 2014
    #4629
    They're running the IDS now. The SA told me if no fault code was detected we're gonna do a roadtest to simulate the incident while running the onboard diagnostic. I'll update you with the result, if there is any. Im just wondering why it has to go on limp mode when it activated the precollision warning.
    Aug 2010
    #4630
    Mga sir do you know a good shop for ford parts? Where can I buy power window mechanism assembly for 2010 ranger?https://www.tsikot.com/forums/images/smilies/bowako.gif
    Aug 2014
    #4631
    Just to give you an update, the result of IDS of course no error, but the roadtest to simulate the incident gave the same result as mine ( as told by the SA). Dina ko sumama sa road test baka ibangga nila eh. The conclusion: Part of the safety feature when adaptive cruise control is active. I just need to confirm if you dont have to restart but shift to neutral just what sir yebo said. The SA told me this was also their first time to experience the feature (safety?). Thanks to my unit. What do you say guys?
    Aug 2013
    #4632
    Quote Originally Posted by rexer29 View Post
    Thank sa reply Sana nga okay na...hassle pag sa long drive tas biglang bumigay lalo pag gabi at nasa TPLEX hahahaha...yong sa unit ko di pa rin napalitan dahil gahol sa oras at 3 days daw ordering time eh paalis na ako the following day palabas ng bansa kaya sa April na lang siguro pag balik ...sana Sir rexer29 di na bumigay ulit
    #4633
    My mother got her black 4x2 Everest Titanium Plus. Ngayon lang ako nakadrive ng car na madamin electronics. Haha. Walang sinabi digital tach ng civic FD ko. Hehe. A few questions lang. Sa manual wala ako makita na way na imanual adjust dimming ng rearview mirror. Auto lang talaga? And wala din builtin GPS navigation? Last for now, is there a way to skip music using steering wheel control kapag source is mobile phone via bluetooth?
    May 2011
    #4634
    Hi guys. Sorry if na may mga posts na about this but I've tried using the search box and I can't seem to find any related post. What could be the reason for check engine light (cel) on our 6 day old eve? Just want to get your insights before I bring her back to our dealer tomorrow.
    Jun 2010
    #4635
    Saksakan mo ng obd2 tester, check mo kung anong error code, madaming reasons bakit iilaw check engine.. for me pinaka common ay ung di gaano naka close ung gas tank cover
    Sent from my ASUS_T00J using Tapatalk
    May 2011
    #4636
    Quote Originally Posted by gomez_ea2 View Post
    Sadly wala pa ko nyan. Probably best to have that in cases like this. I checked the gas lid earlier and ok naman. The light went off after a few restart. I'll observe it muna bago ibalik sa casa.
    #4637
    time to renew my eve's insurance. ano ba lowest kaya for a 3.2 titanium premium?
    Mar 2007
    #4638
    Sir paquote ka ng lowest sa internet then patapatan m sa bgc basta me printed quotation k ok sa kanila
    #4639
    Quote Originally Posted by bigeebabee View Post
    quote ng ford bgc 52k. taas e.
    Jun 2010
    #4640
    About to renew my insurance, as per my insurance estimated current fair market value of my 2016 eve 3.2 totl is 1,699,000.00.
    Premium ko ay 39,137.50
    Coverage
    Own damage/theft: 1,699,000.00
    Bodily injured: 100K
    Prop damage: 100K
    Free UPPA: 22,000.00
    Participation: 16,990.00 (1%)
Ford Everest 2015
