Page 220 of 389 FirstFirst ... 120170210216217218219220221222223224230270320 ... LastLast
Results 4,381 to 4,400 of 7777
    #4381
    Problema kasi sa everest di pansinin kung naka off na lights kaya minsan nakakaligtaan na may light na naka on. Ako ilang beses na forget ko yung lights, minsan nga nag door bell pa neighbor ko ng midnight para sabihan ako na naka on pa yung park lights.
    No sound alerts if may naiwan na open na lights when the drivers door is opened?
    Jun 2010
    #4382
    ^^^ Pag headlight may sound pag open mo ng door
    Sent from my ASUS_T00J using Tapatalk
    #4383
    May nakita akong white trend na naka honeycomb grill sa visayas ave naghatid sa school ng anak ko kahapon before i left for the airport. Meron na daw sa banawe. Although di ko type yung grill nya (may ford logo na hindi pwede alisin) complete replacement ito dun sa oem grill. Sana meron na din yung walang ford logo, plain honeycomb lang. Or at least yung naalis yung ford na letters.
    Jul 2016
    #4384
    For interior lights like map light and dome lights wala, pero may feature ang eve/ranger if ever maiwan mo man bukas ilaw, at nareach critical battery voltage, i shutdown nya ung buong electrical system to prevent battery from fully draining and makapagstart ka pa.(hopefully... LOL)
    Sep 2009
    #4385
    Meron na ba updated list ng difference ng ambiente vs trend?
    Oct 2015
    #4386
    Quote Originally Posted by Janemar View Post
    Sir may sound po pag naiwan nakabukas yung headlight aa trend
    Jul 2016
    #4387
    Quote Originally Posted by eveg4 View Post
    Yes sir may chime po if you forgot to switch off HL and turn OFF engine pero i find it useless since ishushut down din naman ng BCM ang HL once you turnOFF engine and remove the keys.
    Ingat lang, if you accidentally hit the "high beam flasher," Iilaw HL and di sya mag chime alarm and di rin i turn OFF ni BCM even if you lock the car.. Mag OFF lang sya as I mentioned, if na reach na nya critical battery voltage...
    Jul 2016
    #4388
    Been fiddling with my everest this afternoon. Manage to disable the FF:
    1. Annoying chimes pag open ng driver door while parked. (Di na magigising si Baby when we arrive home ;p)
    2. Turn OFF DRL
    3. Oil Life Option
    Next time, try ko naman enable DDS(Hindi ito davao death squad ahh! LOL!), engine Run Hour meter, Remote Start and remove speed limiter.
    ^^Engine Running, ALL Lights turned OFF = NO DRL!
    ^^ECU Diagnose and Reset codes. Okay naman si everest, no pending DTCs found.
    Jun 2010
    #4389
    ^^^ sa mga bagong version b yan ng everest sir.. parang di ko yan nakikita sa settings ko lalo ung oil life
    Nov 2015
    #4390
    mga sir, sa mga naka 4x4.. pag umuulan ba ay mas okey kung yong TMS ay nasa grass, gravel & snow mode? kasi noong nasa NLEX ako basa ang daan at naka normal mode ang aking eve..nag-aalarm prompting me to re-assess TMS mode pero binalewala ko lang and continue driving...thanx
    Jun 2010
    #4391
    ^^^ for me NO, kasi ung TMS nya need it to specific condition like mud, snow, sand, gravel, rock, so in other words when you really needbto engage heavily ung front diff.. although our everest is AWD, kung ginamit mo ung TMS sa patag, your giving wrong info and ung stress sa transmission.. just my 2cents. Even sa heavy rains at may baha, di ko pa nasubukan ma prompt ng TMS.. baka ung selector mo sir wala sa.normal mode..
    Jun 2010
    #4392
    2. Turn OFF DRL
    3. Oil Life Option
    Anong variant everest mo si? kasi check ko kanina ung akin, di pwede disable ung DrL, auto high beam lang ung option, tapos wala ako makita na na oil life sa menu..
    Jul 2016
    #4393
    I use Forscan sir to edit those features.
    Jun 2010
    #4394
    Forscan?
    Mar 2007
    #4395
    ano model available to n d b mavoid warranty tia
    Sep 2009
    #4396
    Ano unit mo sir? May ganyan din kaya ang trend?
    Jun 2010
    #4397
    Ano ba ung forscan? Like scanner ba un?
    Jul 2016
    #4398
    Quote Originally Posted by gomez_ea2 View Post
    What's new
    ^^eto po link sir sa mga gusto i try. Natuto lang din ako dyan.
    Mar 2007
    #4399
    [QUOTE=Janemar;2768535]What's new
    Paano connection thru usb and laptap ano version ng software ty
    Sep 2016
    #4400
    ..new owner here, mas maganda ba UniOil diesel?
Ford Everest 2015
