Page 223 of 254 FirstFirst ... 123173213219220221222223224225226227233 ... LastLast
Results 4,441 to 4,460 of 7777
    Apr 2009
    Quote Originally Posted by mda View Post
    Protect the EPS motor from?
    Is this a top shield, bottom shield, etc?
    While I don't have complete info at this time, it's likely for offroad use, which is probably why the 4x2s aren't given these as standard.
    Do the 2.2 4x4 have these din? If yes, it probably confirms my guess.
    Wala pong 4x4 na 2.2
    Sent from my GT-I9505 using Tapatalk
    maduming brake switch? pag nagalaw galaw lumilinis?
    Badtrip din yung ayaw pumihit ng susi. Twice na nangyari sakin yun then once sa sister ko. Kahit anong galaw ko ng manibela ayaw pumihit ng susi. Not sure paano ko napihit susi eventually lol
    Quote Originally Posted by marky2115 View Post
    Badtrip din yung ayaw umikot ng susi. Twice na nangyari sakin yun then once sa sister ko. Kahit anong galaw ko ng manibela ayaw umikot ng susi. Not sure paano ko napaikot susi eventually lol
    ive had that issue sa eps ko 3x when my car was 1yr old. never had it since. learning experience
    need mo push in ng konti yung key before turning para alisin. habit ko na yan na push in before turning off kasi most cars key start switches have a lock where you can not remove the key if you don't push it in before turning to the off position. so hindi ko na pansin kung ganyan ang key start ng everest. i would be surprised though if it is not.
    baka kailangan ng picture..😅
    how do you upload a photo
    Actually pinush ko na din susi before pihitin from Lock all the way to Start and also slightly turning the steering wheel during turning the key pero both ways di nagstart initially. Di ko talaga alam paano ko naresolve. Hehe
    Edit: When starting ko lang pala naexperience to. I don't remember kung pati pagpatay naging issue sakin
    May 2007
    nakita nyo na yung bago price list ng ford? bumaba pick up . mahal na ng trend
    Nov 2017
    Quote Originally Posted by eido View Post
    lalong lalakas benta ni ranger kaso lalo hihina benta ni eve [emoji26]
    Jan 2016
    2018 Prices (Top Gear)
    Ambiente MT > 1,518,000
    Ambiente AT > 1,578,000
    Trend > 1,718,000
    Titanium 4x2 > 1,918,000
    Titanium + > 2,058,000
    Titanium 4x4 > 2,288,000
    Jan 2018
    mga lodi goodpm po. 2017 ford everest need po ba ng canbus for h.i.d kit. kase nag install po ako pero once i start the engine nag shut down headlight pero pag ignition on lng (engine off) the hid works fine
    I think you need to change in forscan the bcm from halogen to hid
    Sent from my SM-A720F using Tsikot Forums mobile app
    726-27-01 0000 xxxx xxxx - Front Light Outage Detection Disable when adding aftermarket LEDs/HIDs in Halogen Bucket
    Jan 2018
    Quote Originally Posted by alrorskyz View Post
    ayun lang wala ako forscan...pero confirmed gagana daw basta lagyan ng relay.. any issue kaya kahet hindi galawin sa forscan?
    pagginamitan ba ng forscan ma void agad warranty? if so ayaw ko muna
    Jul 2016
    Quote Originally Posted by s2kap1 View Post
    1. Di pede Relay lang, you need equivalent sized resistor to fake the BCM into thinking na may nakakabit pa na halogen bulb.
    2. Di mavoid warranty using forscan.
    3. Mas ma void warranty if nakita nila may nakakabit na chingchongching HID kit and Relay sa engine bay mo.
    4. Just buy a BCM friendly HID kit kung alang forscan.
    5. Switch to clear tints for windshields(anytime baka maghigpit na rin naman LTO) + upgraded halogen bulbs like osram NB.
    Hindi na void warranty if you change settings using forscan.
    Mas ma void if makita nila may relay kinabit and wire splicing.
    Forscan is free but you need to buy OBD that will support forscan.
    my wife made a trip to zambales today to fetch my mother's caregiver. she went at 170 kph at sctex. maingay na daw yung engine starting at 160 kph. i did changed the air filter with a huricane filter, baka siguro kaya naingayan siya. and then there is the issue with the mud terrain tire she bought when the right rear nitto got slashed.
    and my top speed on the eve was only 145 kph and she starts to scold me at 130kph! unfair!
    more air sounds good on gas engines.. so sa diesel hindi? 170 lol talo pa nya ako hahahah
    maingay yata talaga basta washable filter. i remember someone here used k&n on his eve and maingay din ang report. i did noticed an increase humm when i first put it in 3 weeks ago.
    kaskasera talaga e. di pa naman nabigyan ng speeding ticket kahit na-flag down na sa sctex noon. nahuli daw siya kanina sa sbma not for speeding but for failure to stop at a 4-way stop. dinaan na naman sa pa-cute. sabi ko nga di lang tiniticketan kasi babae siya.
Ford Everest 2015
