ask ko lang mga sir, sino may roof basket sa everest nila? especially sa naka panoramic roof..? thanks
Sent from my RNE-L22 using Tapatalk
me. pero inaalis ko pag di ko naman ginagamit kasi malakas ang wind noise. i just have the chipipay generic roof basket na tig 5k from banawe. the roof crossbar is the slim type so di siya gaano maingay. that one stays on permanently.
make sure when you install the roof cross bar that the forward half of the panoramic roof can open upwards (2 modes di ba, 1st mode the roof opens up for ventilation to get rid of hot air, 2nd mode the roof moves down and slides rearward). when they first installed my crossbars i could not do mode 1. so i had to slightly make the crossbars shorter for the clamp to fit the next notch back of the roof rack.
this is it's position now. the crossbars cost 8.5k in banawe, the exact same model is being sold by some seller active in the ford everest club for 35k before.
yan din problem ko ngayon may konting whistling noise lalo kung nasa 80kph ka na.. even may wind fairing na ung roof basket, baka dagdagan ko na.lang ng wind fairing hanggang dumikit sa roof ng everest para wala ng butas sa harap. ewan ko kung dahil lang ba sa panoramic roof kaya rinig ko ung whistling wind noise na yun, na kung walang pano roof, baka di mo na yun maririnig
palagay ko no kasi mas less ang sound transmission through glass kesa metal. maingay lang talaga siguro yung chipipay na roof basket ko. ang gusto ko talaga na ilagay ay roof box pero 2nd hand lang. not worth it gumastos sa 35k thule roof box na 1-2 times lang naman magamit per year.
try mo ung sa rhino rack na.pioneer, flat sya, low profile type' pero tingin ko mag kakaroon pa rin ng tunog due to dragging, kaya kahit ano ilagay mo, mag kakaroon ng wind noise, ang tanong na lang ay kung ano acceptable sa pandinig mo,[emoji4]
medyo maingay talaga lalo sa 80kph, pero tolerable naman lalo kung naka radio ka naman..
may naka experience ba sa inyo na minsan wala lumalabas na hangin sa rear for aircon, sa side lumalabas ung hangin (ung vent sa may likod ng 2nd row seat, kahit turn on-off ko ung power ng aircon, pero nung pinatay ko ung engine , then on ulit.. umayos na
wala sir, naka off ung vent sa baba, tapos, kahit pindutin ko ung dual or naka off ung dual, wala pa din, sa side pa din lumalabas ung hangin, pero after ko re-start ung engine, nag normal function na sya
so far wala naman na sir, back to normal operation na sya, turn off then on ko lang ung engine..
yes sir, ok na. minsan pa nga mainit ung lumabas na hangin sa baba, sa may paanan (sa 3ed row) pero naka cold ung temperature nung air con, sinabi ko sa SA ko, nag try sila kung ano anong scenario, di nakita, so far di na sya naulit.
May forscan ka sir di ba?
Check mo if may dtc. It will log a dtc for hvac blend door and vent door position error if may problema man.
If pinatay mo na engine, nag re-calibrate ung position sensor. Maingay sya pag sira ung motor, di nya makita ung position na target nya.
