Friend of mine does it for 2.2 and 3.2.
Brand is upsolute
How much did Ford save by not including glove box and tailgate locks sa 2.2 WT? May mabibili kaya na tailgate lock sa casa? gusto ko palitan yung sa akin.
chips are an easy modification to shift more torque and power to lower rev ranges ... (don't expect to get more power and a lower fuel consumption at the same time as some vendors want to make you believe...) consider, that every time you ask for more power there will be higher wear and tear, on engine and drive train components, brakes and tires - that's the physics ...some chip vendor will give a "warranty" wrt engine and drive train damage: they can do this because they still operate the engine in the same performance range designed by manufacturer via the engine map, but closer to the max. threshold.
Additionally be also aware that more power means more heat the cooling system of the engine has to cope with. While I still believe that most of the overheating issues are caused by lack of coolant in the system a few cases might be also caused by tuning chips: owners are happy about the higher torque when pulling their vehicle up a steep hill ignoring at the same time that the additional heat needs to be exchanged via the same, unmodified cooling system...
I'd rather my car have a shorter lifespan with more fun than keep it for decades, perpetually short of low-end grunt.
As long as the car lasts a good 5-10 years with minor mods, I'll be happy. Would you have experience of chipped diesels conking out prematurely?
Posted via Tsikot Mobile App
The roller cover installer will install 2 dead bolts on the inside of the tail gate that will allow you to lock the tail gate from the inside. The dead bolt can only be accessed when the roler cover is opened. It is also spring loaded so pushing the tail gate closed automatically locks the tail gate.
Is your ranger having issues with low end power?
I have a chip on my Sta Fe before for a year. But then 1 day the engine suddenly fails and went into limp mode.
It was an injector problem and that was due to the chip. It just tricks the ecu about the rail pressure. The injector
can't handle no more.
It's not an issue per se, it's just that the turbo lag is pretty significant. A 2.2 turbo (that isn't made by Hyundai or the Germans) relies too much on boost and thus is pretty lifeless below 1500 rpm.
With a chip, I expect an increase in power across the rev range that will be most felt in lower rpms.
What did you do next to repair your Sta. Fe?
^Almost all chips do is raise injector pressures fooling the ecu to operate outside tolerances causing premature injector damage. Piggyback or re-mapping the ecu i think is the same.
Has anyone tried a pedalbox? I've heard this is better than chips in reducing turbo lag. Im curious to know also if somebody got water injection on 2.2 and 3.2, what are the gains?
From my understanding, chip tuning increases pressures to maximum tolerable limits and not past it. Naturally, manufacturers are conservative with their boost settings since each engine has its own variances and they need to come up with a one-size-fits-all setting.
Since you are using the chip to fine-tune your particular engine, you can set your boost closer to your engine's tolerances.
Please correct me if I'm wrong
