Page 137 of 359 FirstFirst ... 3787127133134135136137138139140141147187237 ... LastLast
Results 2,721 to 2,740 of 7178
    Sep 2010
    #2721
    Quote Originally Posted by koyuryeta View Post
    I'll try 33psi. 35psi yata ang minimum as indicated in the driver's side door, then around 48psi if loaded. Are you using Nitrogen as air alternative bossing?
    Yes, had the air replaced by Nitrogen. Mas stable kasi Nitrogen compared with air. Air kasi expands when your car is running lalo na kapag long distance.
    Sep 2010
    #2722
    Quote Originally Posted by clairenceh View Post
    95k with nitto 265/50/20. Hindi ko alam kung grappler eh, basta nitto. Nagtanong lang ako dati. 75k kapag mags only.
    Eto sir fb page ng Concept one wheels. Concept One Wheels | Facebook
    Here's the website of Conceptone Wheels for the listing of their rims Concept One Wheels - Innovative Technology
    If you want more choices here's another one from Banawe Car Care Center or Dubs Unlimited along West Avenue http://www.bccwheels.com/
    Dec 2012
    #2723
    Guys, would you recommend the Hankook tires? DynaPro ATM?
    Nov 2011
    #2724
    Quote Originally Posted by nicenz View Post
    Hankook siguro ok na kasi yan na gamit ng sta fe di ba? not sure sa ibang hyundai..
    Mar 2013
    #2725
    Quote Originally Posted by JX290 View Post
    Ganun din sa akin noon, medyo may black smoke, pero hindi naman gaano but noticeable, pero ngayon wala na. Isang beses pa nga nung nakipag habulan ako at binigla kong mag apak ng gas, ayun, sobra black smoke, akala ko ano yun sa likod ko, hahaha. pero ok na ngayon, wala na akong napansin. Sa sinabi mong ist gear maingay, wala akong napansin sa unit ko.
    So normal lang pala if bago pa, nagulat kasi ako nung nakita ko sa dealership yesterday, pagrevolution nang brandnew ranger pag labas sa casa para deliver sa new owner, umosok kasi agad.. kakareserve pa lang kasi namin..
    Sep 2004
    #2726
    Black Rhino on the left, WedsSports sa Right.... Both 20s. 50k mga mags dito.... Sa banawe ba mga magkano? Still canvass pa ko sa mga mags... Still looking for a better deal and quality-looks....
    wedsport for me... make the tire size 275/55/20. para brusko pa din tingnan.
    #2727
    Guys ano ba ang re recommend nyong size ng tires sa rm20s....? 275/55 or 275/60 or 285/ 50? Paki explain po sakin ang mga differences nito. Thank you po.
    Examples of tire sizes:
    275/55R20
    265/60R18
    285/50R20
    265/65R16
    The first number is the width of your tire (lapad ng gulong) in millimetres (mm).
    The second number after the / is the aspect ratio or "series" of the tires. In plain english, it is used to compute the thickness of the tire wall (kapal ng gulong). The number is a percentage (%) of the first number. For example:
    265/50 = 265mm lapad ng gulong; 50% of 265 = 132.5mm thickness ng gulong
    195/50 = 195mm lapad ng gulong; 50% of 195 = 97.5 mm thickness ng gulong
    275/35 = 275 mm lapad ng gulong; 35% of 275 = 96.25mm thickness ng gulong
    The number after the "R" is the diameter of your wheel/mags in inches.
    R20 = 20 inches
    R17 = 17 inches
    R15 = 15 inches
    #2728
    Now.. how do we compute the ideal tire size for 20" wheels on Ford Ranger?
    Stock Size: 265/65R17
    265mm = lapad ng gulong. Syempre mas maganda kung parehas or mas malapad yung gulong kung mag-upgrade. So dapat equal or more than 265.
    65 Series = 65% of 265 = 172.25mm thickness ng gulong
    R17 = 17" stock wheels
    Total Diameter of wheel AND tire = 17" + 172.25mm + 172.25mm
    Total Diameter of wheel AND tire = 30.56 inches
    The new tire size should also be more or less equal to 30.56 inches. Anything bigger/smaller by 5% will make your speedometer read WRONG speed, and maybe even destroy your stock suspension, transmission and engine.
    Option A: 275/55R20
    275 = 275mm lapad ng gulong
    55% of 275 = 151.25mm thickness ng gulong
    R20 = 20 inches wheels
    Total Diameter = 20" + 151.25mm + 151.21mm
    Total Diameter = 31.91 inches
    This is bigger than stock diameter by almost 4.4%!! It will surely mess up your speedometer reading.
    Option B: 285/50R20
    285 = 285mm lapad ng gulong
    50% of 285 = 142.5mm thickness ng gulong
    Total Diameter = 20" + 142.5mm + 142.5mm
    Total Diameter = 31.22 inches
    This is bigger than stock diameter by about 2.2%!! It may mess up your speedometer reading.
    Option C: 265/50R20
    265 = 265mm lapad ng gulong
    Total Diameter = 20" + 132.5mm + 132.5mm
    Total Diameter = 30.43 inches
    This is the closest to stock diameter!!
    Aug 2012
    #2729
    Very informative! thanks man! Now I know a lot more in case I want to change rims in the future haha. May downside ba if i retain ang wheel size (265mm) but the ratio would be bigger? I like the look of fat wheels. Possible ba yun? Rims kahit stock ok na sakin, papa paint ko nalang ng black, cheap alternative, new look
    Sep 2012
    #2730
    kanina, nagkamali ako sa timpla, na over rev ko to 4k+ rpm, nalunod sa black smoke yung jeep na iniwan ko...
    Mar 2013
    #2731
    Quote Originally Posted by jUs- View Post
    275/55R20
    265/60R18
    285/50R20
    265/65R16
    R20 = 20 inches
    R17 = 17 inches
    R15 = 15 inches
    Sir jus- thank you for your explanation. just wondering how to read mags sizes.
    Mar 2013
    #2732
    Hi fellow tsikoteers and ranger owners, just got our unit today from ford commonwealth, Manual transmission.. Nag reserve kame last wednesday by the way Based on my observation, mas higher rpm nararamdaman yung torque.. Totoo yung sinabe nung isang fellow ranger owner, sa simula kelangan pa amuhen muna yung kabayo kase pumipiglas pa hehe.. Sa tingen ko sa tamang seating position makukuha para mas swabe tapak sa clutch.. Mausok pa yung unit ngyon, pero siguro mawawala pag na break in na or 1st pms ( sana ) hehe.. Ang lamig ng Aircon. As usual pick up yung unit nten, wag tyo mag expect ng car-like ride, pero tolerable naman..
    para sa mga tsikoteers na gustong kumuha or mag inquire ng ranger, Rerekomenda ko yung sales manager na kausap namen.. Derecho po cya kausap lalo na pag dating sa release date, very accommodating pa.. Pm nyo ko guys if you need his help..
    #2733
    Kung makita ninyo kung gaano kausok ang 4d56 vgt at nissan navara, matutuwa na kayo sa smoke emission ng ranger. I've had a strada and it smokes like ****. The only small engine diesel we own that's "A" on smoke emission is our hyundais. Bilib talaga ako sa hyundai. But it doesnt have the toughness of a pickup...
    Aug 2012
    #2734
    You can fill your tire with Nitrogen? Where can you get that.?
    Aug 2012
    #2735
    Quote Originally Posted by Warning_26 View Post
    PM'ed you bro
    Dec 2012
    #2736
    Thank you so much for the infos! So hindi pala pwede ang gusto ko? 285/55/20 for our All new Ranger? Hmmm....
    Aug 2012
    #2737
    I've been using UNIOIL EURO IV diesel and so far so good, although no change sa FC but no black smoke, I mean, there is a bit not completely black parang grayish lang and that is when I tried to step on the accelerator when I was parked to check the emissions. I agree with one of the tsikoteers, as compared to the STRADA although I am not sure if it really has something to do with the type of DIESEL but I think it has something to do with it. I've been using the UNIOIL DIESEL for 4 months now and engine is running smoother as compared to when I was using SHELL V POWER DIESEL...
    Dec 2012
    #2738
    Guys, sino sino mga naka black rhino 20s dito? May mga effects ba sa handling, suspensions? Sa tagtag and etc?
    Sep 2010
    #2739
    Quote Originally Posted by gsprimetime View Post
    Yes, you can! Sa mga wheels and tire shop meron na yan.
    #2740
    Ganito ang paint talaga ng Ranger no? Nagtanong na ako sa paint shops and wet sanding daw then re-apply ng clearcoat. Same price ng hilamos para mawala. Nakaka OC!
2012 Ford Ranger
