The engine type really does not matter it will do close to the same on any turbo diesel, you can expect a 15% to 20% increase in power. I don't have the specs on how much that engine makes but judging by the 110hp it's not going to be over 10psi.to 12psi The turbo is also very small so that means inefficient and high outlet temps which is less power.
Now I am only assuming this is on a Starex. And since they have a all but useless top mount intercooler you would see some good gains in power.
Here's what it did on a 2001 starex on stock boost.
50/50 water methanol stock boost
70/30 water methanol stock boost.
