Page 17 of 26 FirstFirst ... 7131415161718192021 ... LastLast
Results 321 to 340 of 511
    Dec 2007
    #321
    You can use any alcohol, You will have to water down the 70% to a 50/50 or lower ratio. I have plenty of extra stickers with me when I am there.
    You have to change your oil early because of the cleaning power of the system. All that soot and carbon will get knocked loose. It's best to do 1500klm to 2000klm the first oil change and the next one at 3000klm after that the oil should be much cleaner.
    When the float level sensor is activated the 3rd LED on the controller will flash. The switch is simply a ground wire.
    #322
    ok then doc, i will use some rubbing alcohol later. will just use a smaller ratio. probably 20% mix first. will get some stickers from you when i meet you
    as for the LED light, the first light (power) is always ON, then the 2nd (pump) turns on every once in a while. the the 3rd (full) blinks every so often. although the float switch is not yet wired.
    #323
    Dvldoc,
    I have a Stage 1 set up that I'd like to have a dealer check out. Will Berrima check out my install and propose changes? Or will they only touch what they installed?
    Jan 2011
    #324
    already had my WAI installed by Berrima yesterday. Although the labor charge is on the high side, I was very happy with the install. very professional and OC yung installer. he even cleaned my engine bay after the install.
    during the install:
    after the install: sorry medyo madilim. will take better pictures
    sir cb, pa PM naman how much installation sa Berrima ng WAI. TIA.
    Jan 2011
    #325
    dvldoc, after when can I go back to my regular OCI? should be okay after the 3000k oil change? TIA.
    #326
    Quote Originally Posted by tuazon7 View Post
    sir, i paid 3k for the install + 500 for 2 hose clamps, wire looms, some wires, electrical tape.
    Dec 2007
    #327
    They can check it but I am sure they will charge.
    Or you can just PM me with your question if your having problem with it or need to know how to test it.
    #328
    Dvldoc, when is the best time to get an emission test? After 1500km of use of WAI? And should i also have my exhaust system flushed?
    Dec 2007
    #329
    As long as the system is active while they are testing it should come out pretty low, It will be lower the longer you wait. Exhaust flushing is a waste of money.
    #330
    Quote Originally Posted by dvldoc
    Dvldoc, i meant flushing the exhaust by putting a garden hose in the exhaust and simply flish it with water
    Dec 2007
    #331
    Other than letting a sooty mess run down your local drain it really serves no purpose. You might as well dump oil on the ground. Unless your capturing what is coming out I am not a fan of that practice.
    #332
    Thanks doc. Noted on this hehe will not do it anyway.
    Dec 2007
    #333
    FYI now 300psi pumps now.
    #334
    After using devilsown for the past 4 days, i am very happy with the purchase. With using only 20% rubbing alcohol, the engine feels smoother and the power is finer when the WAI in on. Have to make some adjustments lang at it is now set to 6psi and it uses a lot of water.
    #335
    Would just like to share the emission result i got after 4days of using the WAI.
    I was expecting a lower emission result hehe
    Dec 2007
    #336
    you would have to set the system very low for it to come BBC on during a emission test. I got a 0.25. and a .45. with the system of after having it on the van for a 3000. got to do another on next week when I get back.
    #337
    Doc, how low of psi should i set it at during an emission test to activate the kit? Right now it at 6psi
    Dec 2007
    #338
    Your vehicle needs a lot of revs in park to make that kind of boost. You will probably not even hit 2psi in a emission test. Plus the longer you run the system the cleaner the internals will be so next years will be much lower.
    #339
    Ok doc. Next time will put it in 2-3psi instead for emission test hehe thanks
    #340
    ey doc,
    familiar with engine D4BH, 2,497cc, diesel intercooler turbo (TCI)? Will it benefit from AI?
    how much boost does it currently make (stock) and how much max can it take with AI?
    reference here:
    http://hyundaiengine.com/data/ENGINE%20CATALOG.pdf
Water/Alcohol injection Turbo Diesel use
