I/H/E generally won't hurt gas consumption unless it's poorly done. Poor gas consumption MAY result from IHE mods in the following cases:
1. MAF malfunction due to aftermarket filter: if the aftermarket filter doesn't filter well enough, or if you over-oil your K&N when using the recharge kit, you can damage the Mass Airflow Sensor, which will cause poor running.
2. Improperly fitted exhaust components: Poor joints and gaskets cause exhaust leaks, causing increased fuel consumption.
3. Improperly tuned exhaust components: Too large an exhaust will destroy low rpm driveability and fuel economy. While you generally want your exhaust to flow as freely as possible, if you make the tubes too large, this causes poor flow and turbulence at low exhaust velocities.
From experience, most Simota filters don't provide much more power than stock. Maybe 1-2 hp if you're lucky... and less than none if you're not. Hardly worth the money. An original K&N filter will give you 3 hp or so on a stock car. It doesn't sound like much, but it helps sharpen throttle response, and will provide even more power when combined with a good exhaust system.
