Results 1 to 10 of 1023
November 2nd, 2007 07:42 PM #1
Hey guys, any feedback on Royal Purple Oil? It seems to be in the same price range as Motul H100. I wonder, does it give the same protection, and performance as the similarly priced Motul? And would there be Royal Purple's for diesel?
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 3rd, 2007 12:43 PM #2Royal Purple is good quality oil. Check mo itong thread: http://tsikot.yehey.com/forums/showthread.php?t=42843
Eto naman website nila: http://www.royalpurple.com/
They specifically recommend the 15w40 for diesel.
November 4th, 2007 03:15 AM #3
recently used royal purple for my matrix crdi here... like any other oils out there so far okay naman...
kay SpeedyFix Shaw ka kumuha ng Royaltru Orange...este, Royal Purple pala...
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 5th, 2007 09:06 AM #4yup the 15w40 is diesel rated. so is the 10w40 actually pero better to use the 15w40.
chuaed, maling kulay yun bro! hahahaha!
November 5th, 2007 11:37 AM #5
based dito sa test ibig ba sabihin eh mas maraming napasang tests yun 10W-40 compare sa 10W-30? so mas maganda ang 15W-40 dahil mas marming tests na pumasa?
royal purple motor oil test
Multi-Grade Oils — Typical Properts1, Part 2
SAE GRADE / API SERVICE ASTM Tests
10W30 SL
10W40 CF-4,CG-4,CI-4/SL
15W40 CF-4, CG-4,CH-4,CI-4/SL,CI-4 PLUSLast edited by shadow; November 5th, 2007 at 12:00 PM.
- Jun 2006
- 2,605
November 5th, 2007 02:17 PM #6
- Nov 2003
- 3,848
November 6th, 2007 07:06 AM #7some of the newer tests encompass a whole lot of other things din. basic rule of thumb is use the viscosity that is recommended by the engine though.
November 6th, 2007 09:12 AM #8
Wow! Nice read. Thanks for the inputs guys. This looks like a better option
November 6th, 2007 01:54 PM #9
I'm actually considering this one. I've been to Mobil1 then Motul H100 .. and now Royal Purple.
November 6th, 2007 03:05 PM #10
Last edited by simplicity; November 6th, 2007 at 03:13 PM. Reason: from RP -> Royal Purple
Not sure if functional nga ba pero yung ibang turbo daw water-cooled na versus oil-cooled. Kaya...
0dometer problem
