Results 1 to 10 of 47
- Jun 2014
- 102
July 10th, 2014 02:39 PM #1ano ba yun? sabi ng mamang mekaniko...papalitan daw sa car ko kase sira na...kalerky....di ko naman alam itsura nun....h
July 10th, 2014 03:07 PM #2
nag me-measure ng airflow na pumapasok sa makina
sends signal to the ECU
pag sira yan di maka idle nang maayos ang makina
- Aug 2012
- 2,767
July 10th, 2014 07:22 PM #3Mass Air Flow (MAF) Sensor
Symptoms of Wear or Failure:
Engine may run roughly or not at all
Poor performance
Excessive fuel consumption
Stalling
Check Engine Light may come on or blink
appearance varies for different brands. normally, the MAF sensor is located after the Air Cleaner and before the Throttle Body.
July 10th, 2014 09:06 PM #4
usually, walang continuity dahil sa alikabok lang. try mo muna i spray ng electronic contact cleaner. pag ayaw pa rin, check the 2 wires inside the sensor, baka napatid lang ang wire, pwede hinang dyan. hope this helps
- Jun 2014
- 102
July 11th, 2014 03:47 PM #7
Was thinking the same thing...
That's one precision measuring instrument right there. A slight change in ECU reading because of fixing it the wrong way could mean engine hesitation or poor fuel economy.
Besides, these parts are consumable items... like O2 sensors or your spark plugs. They are meant to be replaced once they've reached the end of their operational life.
- Jul 2011
- 584
July 12th, 2014 04:27 AM #9
Ummm... Bakit hindi pwede solder kung napatid lang wiring?
July 12th, 2014 06:54 AM #10
yes, sirs. pwede ihinang and we have done it before. may wires sa loob ng sensor na pwede ihinang pag napatid lang ang wires. it is bit tricky but very doable. why buy a replacement if you can repair it. tricky dahil pag nahawakan mo yong wires, grounded na. actually, i learned this when the maf sensor of my 98 sentra malfunctioned. nabasa ko sa forum ng sentra club na pwede palang ayusin. nagawa naman at ok na.
I have a feeling its the other way around...
