Page 2 of 52 FirstFirst 12345612 ... LastLast
Results 21 to 40 of 1023
    #21
    Quote Originally Posted by paolorenzo View Post
    Hi Migs. Puwede ba mag engine flush muna, before pouring in the RP? I still have 3 cans of Caltex Flushing Oil left over, sayang naman. My last change oil is Mobil1 Fully Synth (0W50 yata - US made, not SG). What's your opinion on flushing?
    PM'd you on 40k PMS.
    The Caltex Power Flushing Oil works the same way as cheaper monograde oil used for the same purpose. It's not the type of flushing chemical added to your current oil then drained after 5 minutes. IMO, this is a less risky method of flushing. In my experience, it gets a lot of dirt out, but perhaps not as cleanly as flushing with the chemical.
    Speedy, is it safe to use flushing chemicals every oil change? Or would that be overkill? When would you recommend we flush using chemicals, and not just ordinary or flushing oil?
    Quote Originally Posted by MasterZerg View Post
    nagtataka ako bat kaya mura change oil sa mga gas stations like shell..wala pa ata 1k sabi nung kasama ko na nagpachange oil.libre na daw labor and kasama na filter
    They're using mineral oil most probably.
    Jun 2007
    #22
    ok ang royal purple, 10w40 gamit ko
    nagcompute ako and nadagdagan ang 1km ang gas mileage ko
    bale galing 6-7km/l ngayon 7-8km/l based sa computation ko yesterday (taguig - ortigas)
    overall naging smooth ang takbo lalo na sa gabi (siguro dahil malamig din)
    ^^^anong kotse?
    ano ba talaga ang maganda sa climate natin 10w-30 or 10w-40?
    nagpa change oil na ako yesterday kay speedy fix..10W-40 ang nilagay ko..initial reaction is naging smooth talaga ang engine and pati transmission oil ko nagpa change na rin ako and smooth shifting talaga...
    since I came from mineral oil, I don't know kung maganda ba talaga ang RP or kasi synt oil siya..but over all maganda naman...
    Sep 2006
    #26
    ano po ba difference lets say if you use mieral oil... what are the pros and cons?
    Jun 2006
    #27
    Mineral oil pro: good enough protection, relatively cheap, will last 5000 kms or 6 months some people change at 3 months.
    Mineral oil cons: not as good and long lasting as synthetic.
    Synthetic pro: excellent protection, can last 10,000 kms or 1 year. I think RP claims they can last longer than 10,000 kms.
    Synthetic con: expensive
    Sep 2006
    #28
    i also posted this sa kabilang thread..may nagsabi kasi pangit daw ang synthetic oil sa mga lumang engines.is it true?advisable din ba sa engine na 94 civic esi(efi type) ang synthetic na?
    hinde naman masama ang syn oil, in fact kung mineral nga ok na rin eh what more kung syn oil, sinasabi lang na masama is baka magkaroon ng leak kasi luma na nga ang kotse, but hinde yun syn oil ang reason kundi sira na talaga in the first place yun mga seal, gasket, and since mas manipis ang syn oil compare sa mineral eh makaklusotyun mga oil sa mga gasket na hinde nangyayari dati sa mas makapal na mineral oil...
    OT:
    dude, naiilang talaga ako sa avatar mo...hehehhe
    Nov 2006
    #30
    i had my ESi's oil changed kanina kina SpeedyFix. RP 10w-40 ang nilagay. may
    natira pang almost kalahating bote.
    ewan ko. wala naman akong napansin na malaking pagbabago.
    pero eto lang masasabi ko sa service kina Migs - patok! hehehe... kaya lang may nagtago
    daw nung mga FHM niyo eh. tsk tsk tsk...
    sa susunod magdadala ako ng laptop (may wi-fi sila!).
    ^^^hinde naging mas smooth ang engine mo?
    Nov 2006
    #32
    parang same lang eh. observe ko pa a few more days.
    basta walang immediate na changes both sa performance eh.
    btw, puwede na nga pala payment thru credit card sa speedyfix.
    Jun 2006
    #33
    Quote Originally Posted by simplicity View Post
    talaga? ayos pwede ng credit card sa next service ko
    Nov 2006
    #34
    yep, and no added charge for CC payments ha. kasi harang yun pag ganun!
    salamat ke speedyfix. sana sa susunod mas madaming fhm ha.
    hahaha!
    Jun 2006
    #35
    Sorry :offtopic:
    Speedy, baka next time pwede ng t-cash ang bayad
    :Off-Topic2:
    Nov 2003
    #36
    wrcastro_ph, sure no problem i think drop it also carries RP din now though.
    nyagi, isa sa mga side effects yan. hehehe! happy you like it
    paolorenzo, it's ok naman bro but not really necessary. if you wanna finish up the stocks then walang problema.
    MasterZerg, mineral oil siguro yun na hindi multigrade pa. cheap lang naman talaga yung ganun quality na oil. better quality product is always better. but you have to know how to use it.
    IMm29, i wouldn't use it evey change oil. at most every 2 or 3 siguro. pero the strong chemicals we do not use unless there is a bad case of sludge in the engine.
    washburn, great!!
    shadow, glad you're happy with both the engine and gear oil keep us update about the milage and seeya when you get the oil for your other car.
    simplicity, hahaha! may nagtatago? si maryanne siguro yun... lagi nya inuuwi yung mga bago eh. hehe! thanks bro... feel free to bring your laptop next time
    userfriendly, haha! di pa siguro... i'll have to get subsidized by tsikot kapag ganun. hehehehe!
    #37
    *speedy, ano ma rerecommend mo na viscocity para sa 98 lxi? aroung 65k pa lang ung natatakbo. thanks.
    Nov 2003
    #38
    you're safe with a 10w40 but kung wala pa leaks you can try the 10w30.
    Jun 2007
    #39
    ^^^anong kotse?
    lancer 97 pizza
    Nov 2003
    #40
    how's the milage? ok parin despite the xmas traffic?
Royal Purple Oil
