Page 1 of 103 123451151101 ... LastLast
Results 1 to 10 of 1023
    Hey guys, any feedback on Royal Purple Oil? It seems to be in the same price range as Motul H100. I wonder, does it give the same protection, and performance as the similarly priced Motul? And would there be Royal Purple's for diesel?
    Jun 2006
    Royal Purple is good quality oil. Check mo itong thread: http://tsikot.yehey.com/forums/showthread.php?t=42843
    Eto naman website nila: http://www.royalpurple.com/
    They specifically recommend the 15w40 for diesel.
    Jun 2006
    recently used royal purple for my matrix crdi here... like any other oils out there so far okay naman...
    kay SpeedyFix Shaw ka kumuha ng Royaltru Orange...este, Royal Purple pala...
    Nov 2003
    yup the 15w40 is diesel rated. so is the 10w40 actually pero better to use the 15w40.
    chuaed, maling kulay yun bro! hahahaha!
    based dito sa test ibig ba sabihin eh mas maraming napasang tests yun 10W-40 compare sa 10W-30? so mas maganda ang 15W-40 dahil mas marming tests na pumasa?
    royal purple motor oil test
    Multi-Grade Oils — Typical Properts1, Part 2
    SAE GRADE / API SERVICE
    ASTM Tests
    10W30
    SL
    10W40 CF-4,CG-4,CI-4/SL
    15W40 CF-4, CG-4,CH-4,CI-4/SL,CI-4 PLUS
    Jun 2006
    ASTM Tests
    10W30
    SL
    The 10w30 and 5w30 is for gas engine only. Both are energy conserving oils. So your FC will improve a bit. Hard to put an exact number on your savings.
    The 10w40 and 15w40 can be used for both gas and diesel engines. The 15w40 is a better for diesels.
    Nov 2003
    some of the newer tests encompass a whole lot of other things din. basic rule of thumb is use the viscosity that is recommended by the engine though.
    Wow! Nice read. Thanks for the inputs guys. This looks like a better option
    I'm actually considering this one. I've been to Mobil1 then Motul H100 .. and now Royal Purple.
    Nov 2006
    Quote Originally Posted by speedyfix View Post
    boss, i'm not sure sa viscosity ng engine ko. it's a stock esi engine.
    d'you know po ba kung ano ang viscosity for this?
    if ever, available sana yung viscosity sa Royal Purple.
    Last edited by simplicity; November 6th, 2007 at 03:13 PM. Reason: from RP -> Royal Purple
Royal Purple Oil
