mga sirs would you have any idea where I can buy royal purple here in cebu? thanks
saan po dito sa south ako makakahanap ng Royal Purple? bandang Las Pinas City.![]()
sa pronto po sa may alabang west or east service road ba yun(hehehe confused ako sa directions e hehehe) kung galing kang alabang makalagpas siya ng sharp
Hi,
Just got my Proton wira's (1.6 xli) oil changed this day with RP oil 10w40..First observation, parang tumahimik ang makina at naging smooth ang takbo..I'm not sure kung it's all in the mind, but I'll check for other results..Afterall, I'm after the fuel economy improvement that this oil has promised..Im currently running 7-8li/km * city driving..I'll see..:drive1:
Sa makati area meron ba? And san yung HRC sa banawe? Do they accept CC or cash lang?
the directions to the shop are here: www.speedyfixph.com
yeah i think hrc accepts credit cards. so do we and so does hans tools in shangrila.
hans tools in Shangrila sells RP oil? Great! I'd probably just buy there! Thanks for the quick reply
sir san po ba pwede nakabili ng ROYAL PURPLE oil? dito sa caloocan...ako lang kasi ang nag change oil ng kotse ko...thanks...may semi syn ba nyan?
RP only produces full syn products except for its break-in oil which is not yet available here.
RP Oils are available in Caloocan from the ff:
Drop-It - 8th. ave cor del mundo west grace park
Aerohead - 9th. ave. and 2nd ave. east grace park
El Ultimo - w. shaw st. cor biglang awa
Sir Speedyfix,
I have a Nissan Sentra 98 ex saloon with 115,000 milage. Pwede pa ba sa akin ang RP oil? 10w 40 ba gagamitinor anung recommended nyo na viscosity? and dun sa change oil how much if may kasama na change ng spark plug?
Tnx
Sir Speedy I'm planning to buy again RP oil sa inyo. Last time na bumili ako sa inyo ng RP oil is 10w40 January2009 pa. Now im planning to change the viscosity to 10w30. okey lang po ba iyon? Almost 8 months ko na ginagamit ung RP oil so far so good..
One thing Lang Ive notice na after 7 months medyo nagbabawas ung oil ko.. From Full to HALF na sa dip stick. Then After that nag refill ako agad ng RP oil 10w40. Okey na po ulit... Nasa full na po ulit ung level ng oil ko....
THen sinabiko sa mikaniko ko ung nag babawas na oil after 7 months of using it. Sabi naman ng Mekaniko Okey lang daw un... Top Overhaul na daw namin ung engine SA JANUARY 2010 Sabay na daw sa Change oil. By the way my engine almost 11 Yrs na. TOYOTA 3T 8VALVE LANG SYA OWNER TYPE JEEP LANG PO Auto KO.Pro well maintained ko sya... Always in a good condition.
Also Ive notice na may White smoke na sa Muffler ko pag ni rev ko at normal temp. after itakbo ko ng malayo.. wala na ulit then pag naka park na me pag ni rev ko ng malakas meron na ulit white smoke..
Im planning to buy RP oil 10w30 viscosity this September okey lang po ba ung pag na top overhaul na.. Or gamit na lang ulit me ng 10w40 na RP oil..
Thanks po.
