Page 366 of 390 FirstFirst ... 266316356362363364365366367368369370376 ... LastLast
Results 3,651 to 3,660 of 3899
    #3651
    ^champion lab?
    Sent from my Nexus 5 using Tsikot Forums mobile app
    Mar 2005
    #3652
    yup! pinakita pa nga sa youtube vid ng RP na gawa siya ng Champion labs.
    Sep 2013
    #3653
    Kaya direcho ka na sa mismo maker para mas mura.
    Parang k&n oil filter din yan na rebadge kaya mahal.
    Mar 2005
    #3654
    Sige sir hanap din ako ng products nila na ka spec ng RP filter baka mas mura.
    Eto pala nahanap ko na specs ng OEM Hyundai Filter (26310-27420) na gamit ko ngayon.
    Height [mm]: 148
    Thread Size: UNF 3/4-16
    Seal Diameter [mm]: 70
    Outer Diameter [mm]: 90
    Dec 2008
    #3655
    Di ba cartridge type ang oil filter ng 2009 sta fe diesel?
    Sep 2013
    #3656
    Quote Originally Posted by jmpet626 View Post
    Height [mm]: 148
    Sa baldwin ito ang lumabas : B243 or B178.
    Try mo icross-reference sa champion labs.
    Mar 2005
    #3657
    *narayan
    Yung sakin canister type pa din.
    *chookchakchenes
    Thanks sir! Try ko din yan
    Aug 2013
    #3658
    Anyone used a Baldwin oil filter without bypass valve?
    Right now, been using one, B143 sa 4AFE ko with Delo Gold, more than 3 months na, no oil starvation, pag start sa morning, one click, off kaagad sensor lamp,may konti ingay lang sa tappets pero silent na after 3 minutes.
    Next oci, will use Zic A, 10w40 semi synthetic motor oil and B178, with 30 psid bpv pressure setting, tingnan ko kung mawala ang lagitik ng tappets sa morning start up.
    Posted via Tsikot Mobile App
    Sep 2013
    #3659
    Ang bypass valve ng para sa corolla around 14 psid by pass valve. Pwede ka mag 8psid or 20 psid.
    Yung 30 psid masyado na malayo.
    Aug 2013
    #3660
    Quote Originally Posted by chookchakchenes View Post
    From what I've read sa mga forums about filters, bpv will only engage if media is fully clogged. Yun bang very dirty ang oil na hindi change for a long time at driving condition is very severe, dusty, may fuel dilution, heavily sludged engine, in short, present lahat factors para clog ang filter, wala naman ganun ang engine ko.
    For three months, very normal ang gamit ng walang bpv, what more kung meron pa, kahit mataas ang setting. Confident ako sa high capacity property ng Baldwin compared sa other commonly used filters locally.
    I've used 8 psid bpv filter before, B131, maitim agad oil, think ko, easily engage ang bpv, passing unfiltered oil at high rpm.
    Just my experience...
Remote bypass oil filtration
