Page 183 of 195 FirstFirst ... 83133173179180181182183184185186187193 ... LastLast
Results 3,641 to 3,660 of 3899
    Sep 2013
    #3641
    from bob is the oil guy forum
    Pangit na daw quality ng purolator. Naikumpara pa sa fram "the orange can of death"
    How Did Purulator Quality Control Sink So Fast? | Oil Filters | Bob Is The Oil Guy
    Mar 2005
    #3642
    Ask ko lang po kung paano mag measure ng thread size ng oil filter? Planning to use Royal Purple oil filters pero wala silang pang Hyundai Santa Fe 2009 na Diesel, puro pang gas lang. Since may stock naman ako ng OEM Hyundai Filter. Dun ko na lang sana sa thread size hahanapin kung meron RP oil filter na swak sakin.
    Ano pa po bang considerations when choosing the filter bukod sa thread size?
    May 2005
    #3643
    Quote Originally Posted by jmpet626 View Post
    If the rubber gasket aligns in the same place as the OEM.
    You can search for the OEM number for the gas engine oil filter and do a cross search on RP's website or other filter manufacturer's site. From there you can determine if its the same thread.
    Thanks CB!
    Dumating na din order ko.
    Thanks CB!
    #3646
    Thanks CB!
    dumating na ba? gamitin mo na?
    Yup mamaya. Busy pa. ehehe
    Sep 2013
    #3648
    B243 pwede yan.
    Mar 2005
    #3649
    Thanks sir! try ko din yung baldwin. Anyways kaya sa RP gusto ko try ay dahil nabasa ko yung reviews ng RP sa :
    Oil Filter Comparison Study - GM Truck Central
    at mas madali ako makapag source ng RP Oil filter pag alam ko na yung part#. Been using RP oil filters na din kasi for my Jazz, Rav4 and Sonata.
    Sep 2013
    #3650
    Rebadge ang royal purple oil filter
    Nalimutan ko kung sino gumagawa. Nabasa ko sa bob is the oil guy forum.
    #3651
    ^champion lab?
    Sent from my Nexus 5 using Tsikot Forums mobile app
    Mar 2005
    #3652
    yup! pinakita pa nga sa youtube vid ng RP na gawa siya ng Champion labs.
    Sep 2013
    #3653
    Kaya direcho ka na sa mismo maker para mas mura.
    Parang k&n oil filter din yan na rebadge kaya mahal.
    Mar 2005
    #3654
    Sige sir hanap din ako ng products nila na ka spec ng RP filter baka mas mura.
    Eto pala nahanap ko na specs ng OEM Hyundai Filter (26310-27420) na gamit ko ngayon.
    Height [mm]: 148
    Thread Size: UNF 3/4-16
    Seal Diameter [mm]: 70
    Outer Diameter [mm]: 90
    Dec 2008
    #3655
    Di ba cartridge type ang oil filter ng 2009 sta fe diesel?
    Sep 2013
    #3656
    Height [mm]: 148
    Sa baldwin ito ang lumabas : B243 or B178.
    Try mo icross-reference sa champion labs.
    Mar 2005
    #3657
    *narayan
    Yung sakin canister type pa din.
    *chookchakchenes
    Thanks sir! Try ko din yan
    Aug 2013
    #3658
    Anyone used a Baldwin oil filter without bypass valve?
    Right now, been using one, B143 sa 4AFE ko with Delo Gold, more than 3 months na, no oil starvation, pag start sa morning, one click, off kaagad sensor lamp,may konti ingay lang sa tappets pero silent na after 3 minutes.
    Next oci, will use Zic A, 10w40 semi synthetic motor oil and B178, with 30 psid bpv pressure setting, tingnan ko kung mawala ang lagitik ng tappets sa morning start up.
    Posted via Tsikot Mobile App
    Sep 2013
    #3659
    Ang bypass valve ng para sa corolla around 14 psid by pass valve. Pwede ka mag 8psid or 20 psid.
    Yung 30 psid masyado na malayo.
    Aug 2013
    #3660
    Quote Originally Posted by chookchakchenes View Post
    From what I've read sa mga forums about filters, bpv will only engage if media is fully clogged. Yun bang very dirty ang oil na hindi change for a long time at driving condition is very severe, dusty, may fuel dilution, heavily sludged engine, in short, present lahat factors para clog ang filter, wala naman ganun ang engine ko.
    For three months, very normal ang gamit ng walang bpv, what more kung meron pa, kahit mataas ang setting. Confident ako sa high capacity property ng Baldwin compared sa other commonly used filters locally.
    I've used 8 psid bpv filter before, B131, maitim agad oil, think ko, easily engage ang bpv, passing unfiltered oil at high rpm.
    Just my experience...
Remote bypass oil filtration
