Page 367 of 390 FirstFirst ... 267317357363364365366367368369370371377 ... LastLast
Results 3,661 to 3,670 of 3899
    Sep 2013
    #3661
    Ok sige interested din ako kung ano effect. Nabasa ko kasi dati kay dvldoc na around 6 lang daw allowance pag lalagpas sa bypass valve.
    Tataka ako sa b178 bakit mas mura sa b33 na pang corolla talaga. Eh ang liit ng b33 pero nung nagemail ako sa baldwin ang ganda pala micron filtration rating b33.
    Aug 2013
    #3662
    And B178 is almost twice the capacity of B33, kung hindi ma-clog ang maliit sa one oci, ang mas malaki pa kaya... That's why, no worries for me.
    I also sent email to Baldwin, sabi, if you don't want to worry, use one of the same bpv setting as OEM, 14 psid, but also insinuate, you can't go wrong with the high debris carrying capacity of B143 and B178 with excellent filter media, unless you have a very dirty engine.
    Rule of thumb sa OP, 10psi every 1k rpm. Kung 14psi ang bpv ng oil filter, cruising at 2k rpm, kung maliit filter used at malapit na end of oci, sa sudden acceleration, say, umabot 3k rpm, maybe the bpv will engage, lusot unfiltered oil.
    Posted via Tsikot Mobile App
    Sep 2013
    #3663
    Yung b243 ok din 8psi bypass valve.
    Meron pa isa mahaba 14psi by pass valve nalimutan ko code.
    Aug 2013
    #3664
    Preferred ko Baldwin oil filters with 20 psid and above na bpv setting, 80 mm casing outside diameter, 65mm-70mm outside diameter ng gasket, kahit 130mm long, will fit my 4AFE.
    Sent from my HTC Explorer A310e using Tsikot Forums mobile app
    May 2005
    #3665
    B1402 - Php 360 last year (dont know this year).
    Alternative
    Bosch OF415 - Php 150 (amazon)
    #3666
    Alternative
    late last year parang 390 na bili ko sa 1402.
    Aug 2013
    #3667
    Alternative
    bro, made in Korea Bosch filters mo? Thanks.
    naka bili kasi ako, B33 counter part ng Bosch, OF 110, made in korea. P200 per piece.
    Sep 2013
    #3668
    Ano code yan bosch na 200 pesos?
    Yung b1402 nasa 350 pesos yan sa banawe seller.
    Aug 2013
    #3669
    Quote Originally Posted by chookchakchenes View Post
    Bosch OT-041 (US) or OF-110 (Korea) halos same size siya sa Baldwin B33 at Vic 110, P200 isa.
    Bosch OT-042, same size siya sa Baldwin BT223, P200 din ang isa.
    May 2005
    #3670
    It was 350 back in 2012. If I'm not mistaken, it was 320 before that.
    Quote Originally Posted by innova2013 View Post
    As for the OF415, I did not get to check its country of origin bec. I just asked the messenger to inquire.
    Not all Bosch are made in Korea. Some are also made in indonesia ie. OK 064
    Pls PM me contacts of your banawe supplier. Thanks!
Remote bypass oil filtration
