Page 266 of 390 FirstFirst ... 166216256262263264265266267268269270276316366 ... LastLast
Results 2,651 to 2,660 of 3899
    Dec 2007
    #2651
    The b113 is a nissan one with no bypass valve. I have those in fleetguard but only like 5 of them, i will basically have a bit of everything with me sunday at the world trade center. I will be there to at least 2pm u can get my cell number from my ads.
    #2652
    Had my change oil yesterday. Here's the oil filter element Toyota uses now for the 1ZR engine on the Gen 10.5 Altis.
    This piece of origami cost P318!!!
    The mechanic dropped the used filter into the can before i could get i. I'll take a shot of the used filter during my next service stop.
    Jan 2012
    #2653
    so boss parang refill lang sya?
    #2654
    ^ Yep. And Toyota uses a special tool to remove the canister so when you have service done elsewhere, the mechanic should know how to properly unscrew it.
    I hope better aftermarket elements will become available just as well. The o-ring (seen next to the filter) is also replaced every oil change.
    Jan 2012
    #2655
    that kinda sucks. limits you from using other after market filters like baldwin or FG.
    You are stuck with Toyota OEM for now I guess till there are after market options.
  6. #2656
    Baldwin B2 on a Nissan LD20II. P200 pesoses only courtesy of Volmax. Samantalang yung VIC C209 costs more than P350. Nagiging overpriced na rin ang VIC.
    #2657
    Hindi na lang "nagiging overpriced", overpriced na talaga. hehe
    Jan 2012
    #2658
    yikes. ang mahal nga nung vic. hamak na mas mura baldwin mas better pa.
    #2659
    Quote Originally Posted by bayen View Post
    Very limiting indeed. Hopefully the aftermarket catches up on this.
    Jan 2012
    #2660
    quick questions folks:
    I was checking out Baldwin and FG variants having thread M20X1.5 and i noticed that some have 5 holes on top and some have 8. Most of them have 19 or 20 PSID and thread is m20x1.5. Question is, Does the number of holes on top cause any incompatibility issues with a car? More holes better flow or not?
    Heres a few i noticed:
    B1446 - 5 top holes, 3.8in, 20 psid
    LF3528 - 8 top holes, 4.15 in, 19.5 psid
    B109 - 5 top holes, 5.833, 20 psid
    LF3433 - 5 holes, 5.35in, 19 psid
    B7243 - 7 top holes, 3.5 in, 20 psid
    B1402 - 8 holes, 4in, 14 psid
    B1400 - 8 holes, 3in, 14 psid
    some friends of mine have been requesting for longer filters for their rides but arent available so i figured why not use the ones compatible with other cars like the one for the isuzu, its longer, same thread pattern, same PSID, only difference is the number of top holes. Can you use those instead?
Remote bypass oil filtration
