Page 179 of 195 FirstFirst ... 79129169175176177178179180181182183189 ... LastLast
Results 3,561 to 3,580 of 3899
    #3561
    Dumating na order mo?
    dumating na early this mo. sa tate, pero in transit papunta dito kasama nung mga ibang epektus. early/mid january nandito na yan, yahoo
    Aug 2013
    #3562
    *zix888...meron ka specs or technical descripttion ng Lubricheck? Timbre ko kay utol, baka meron sa place nila, magpa-uwi ako madami. Uuwi siya sa Feb next year.
    Sent from my Light using Tsikot Forums Mobile App mobile app
    #3563
    Quote Originally Posted by johnjoseph View Post
    About this item
    The Lubricheck can pay for itself in just one saved oil change! Like a "Blood Tester" for your car, the Lubricheck can help measure the health of your engine. A few drops of oil placed on the Lubricheck sensor from a dipstick can instantly tell you the condition of your oil and engine. Lubricheck works on trucks, tractors, boats, mowers, ATVs, motorcycles, or any gas or diesel four stroke engine. The results are displayed by lighting LEDs ranging from 1 to 10. Green (1-7) means your oil is good, yellow (8-9) means fair, and red (10) means time to change. A rapid flashing 10 means you may have engine problems. Simply clean off the sensor with an absorbent rag, and you are ready for the next test. Now you can decide when to change your oil based on the facts! Over time, oil additives designed to neutralize acid build-up are depleted, and impurities build up in the oil. The Lubricheck uses a unique capacitive/resistive sensor to measure the levels of acid (TBN) and contamination from soot, wear metals, fuel, water or antifreeze. Many customers have discovered leaks in their cooling systems long before any permanent damage to their engine. By confidently rejecting the outdated, 60 year old advice to change oil every 3,000 to 5,000 miles, most users can easily cut motor oil use by over 50%. Designed and assembled in the USA.
    #3564
    Nag text si CB sa akin... Mukhang nag taas muli si Volmax ng presyo
    Aug 2013
    #3565
    Try nyo sa Trackzone Phil (Baldwin, Fleetguard) na-post na dito ni dvldoc ang address nya, Php700 lang BD7028, mas mababa prices nya compared to Gigatrade (Baldwin, Mann), batakan sila ni Durasales (Baldwin, Fleetguard, Donaldson). Okey naman mga filters nila.
    Posted via Tsikot Mobile App
    #3566
    290 na bt223, 380 naman b1402 sa volmax. Ngiting ngiti si Manny nung bumili ako e
    #3567
    Magkano mo binebenta bt223 mo, bro? Hehe.
    Sent from my GT-P7310 using Tapatalk 2
    #3568
    Renz, i sent you message sa viber.
    Within a year naka ilang price increase si volmax hehe thanks to tsikot.
    Sep 2013
    #3569
    Kung BT223 kailangan nyo meron malapit sa banawe sa cordillera street. Doon bumibili friend ko para sa toyota altis and vios. Madali na puntahan at free parking pa.
    May 2009
    #3570
    sino na nakabili sa volmax ng mga filter heads? or sa kahit saan shop na specialized sa pangheavy equipment parts?
    hanap ko kasi eh baldwin BT839 hydraulic filter at OB1319 filter head.
    Dec 2009
    #3571
    Quote Originally Posted by miked View Post
    pag filter head hanap mo sir mahirapan ka nyan.. limited ang stocks nila locally, sa lahat ng natanungan ko before ang pinaka madami is monark although medyo malalaki talaga filter ehads nila at mostly hydraulics
    Jan 2011
    #3572
    mga gurus, anu ba Baldwin filter for Nissan Grand Livina?
    Mar 2005
    #3573
    Meron po ba baldwin or Fleetguard equivalent for Hyundai Sta Fe 09 2.2 CRDI VGT?
    Sep 2013
    #3574
    not sure though but you may inquire to Volmax Marketing at 244 8425 tomorrow
    May 2009
    #3575
    Quote Originally Posted by miko101130 View Post
    san si monark brader? nakabili ka na ba dati sa monark? penge naman address at contact nos. salamat
    gagamitin kong pang filter sa automatic transmission kasi. yung fuel filter na metal casing sana para simple lang kaso wala ako mahanap na ganun. puro plastic case ang nakikita ko dito samin.
    Nov 2013
    #3576
    Quote Originally Posted by tuazon7 View Post
    B1431
    Quote Originally Posted by jmpet626 View Post
    Canister type ba oil filter mo or element type na?
    Aug 2013
    #3577
    Try mo sa Banawe hanap surplus filter head with WIF filter, ganun lang use ko sa ATF inline filter ko, meron nga lang siya pump dahil sa fuel siya used pero doesn't matter. Usually Korean made makita mo, okey lang. Just test the thread, either a 3/4" - 16 or M20 x 1.5 will do, bring ka spin on filter you intend to use.
    #3578
    PAcer, try mo din sa Monark sa other side of the road lang. Dyan ko nabili yung 1-14 at 3/4-16 thread. Ang kelangan mo 1-12.
    May 2004
    #3579
    any news to baldwin BD7029 availability? or any brand near its specs. sorry its been a while.tia
    Aug 2013
    #3580
    Quote Originally Posted by niwde11 View Post
    Bro, baka BD7028 ang hanap mo? Kung wala makita, BD28 ay pwede din.
Remote bypass oil filtration
