What I'd like to see is something (a sensor maybe) that will tell you when the filter is clogged. Is there such a thing? The bypass on these filters are all just a rubber flap and there is no proviso that tells you when it is in bypass mode already due to clogging. Sure we can change it early but nothing will tell you if it is already clogged even at just say 3,000 kms.
There are filter heads with indicators that tell you when the pressure drop between the inlet and outlet is beyond a certain limit.
I don't know if these are available for small filters though. I have only seen them for big hydraulic filters.
[IMG][/IMG]
